Old 10-30-2004, 07:09 PM
tc3 tc3 is offline
starting trouble...??
i just got a 95 z28. well i havnt got it yet but it will be in my possession thursday probably.
The other night, when i went to move it, when i started it, it takes a long time to start. Like its taking a while for it to build fuel pressure. Its supposed to be getting a air pump or something for the fuel line or something like that, that was on recall. is that going to solve the problem? It idles at 500rpm, sounds steady but is that right? could it just be the iac thats having a problem, im gona try resetting it next time i get in the car...
Old 10-30-2004, 07:41 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: starting trouble...??
well, there wouldnt be an air pump for the fuel system, but if you are in fact getting a fuel pump that needs replacing, then yes, it should fix the problem.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 10-30-2004, 11:24 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
is it hard starting when its warm? cold? both?
1991 Camaro Z28
Old 10-31-2004, 05:30 AM
tc3 tc3 is offline
it does it when cold, i dont know about warm tho... i looked and i think the recall is for an exhaust emmisions air pump...
ill probobly have to wait until i get it back...
Old 10-31-2004, 12:49 PM
89IROC&RS's Avatar
ahhh ok, that sounds beter, those do tend to get water in them.
in that case i would say you need to replace the fuel filter, at least as a starting point, they are cheap, and easy to replace, and cause this kind of condition when they get dirty.
Old 10-31-2004, 02:13 PM
tc3 tc3 is offline
yeah thats what i figured, which would effect engine performance in general right? as long as i dont have to drop the tank to replace a fuel pump then thats good...
thanks much...
Old 11-04-2004, 04:37 AM
tc3 tc3 is offline
just got the car last night, it doesnt do it when warm...
When warm i can hear the fuel pump prime just turning the car on(not starting), but when cold i dont think i can hear that...?
havnt replaced fuel filter yet tho...
Old 11-04-2004, 12:59 PM
89IROC&RS's Avatar
should be able to hear the fuel pump regardless.. cant imagien why you dont.
Old 11-04-2004, 04:08 PM
tc3 tc3 is offline
when i went a few minutes ago, i could hear it again..., so i must not have heard it... does it still sound like a fuel filter...? how much are they? 10-20?
Old 11-04-2004, 04:57 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
idles at 500? mine idles at 800. oh and i have a 95 z28 too....there was a recall on the air pump? how do i find if mines been replaced before i got it?
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 11-04-2004, 09:37 PM
tc3 tc3 is offline
from what i think i know, the recall is only on certain cars on that year, call a dealer and maybe they can tell you, you have to put in your vin number to find recalls for that car. dad works at dealer so he has those tools available...
just noticed if i start it when i just turned the engine off then it will fire right up, if i wait 10-20 minutes when it is still warm then it takes forever to start again...
someone told me that this could have something to do with injectors?
thanks for help...
Old 11-04-2004, 10:11 PM
i checked www.recall.gov and there was no recall only a bulletin recall if your car is still under warantee
Old 11-04-2004, 10:14 PM
89IROC&RS's Avatar
yup, replace the fuel filter, what is happening is when you turn it off, the fuel pressure slowly bleeds out of the fuel line past the regulator. after its been sitting there isnt enough pressure to get the fuel into the cylenders for them to fire. your fuel filter is restricting fuel flow making it take a while for the fuel line to pressurize. its a no brainer deal. it costs less than 15 bucks, and has two hex head fastners that screw into it on both ends in between two halves of the fuel line. its located just forward of the driver side rear tire, about a foot in from the outter ground effects.
Old 11-04-2004, 11:41 PM
DaMoNe6969's Avatar
could also be a faulty fuel pressure regulator.. If they leak, they'l run fuel into your intake as the car sits and flood it.. try the filter first though
1991 Camaro Z28
Old 11-05-2004, 05:16 AM
tc3 tc3 is offline
thanks for help guys...
the recall thing is only on certain vin numbers, just try calling a dealer, they have tools no one else can get...
