how do u remove steering pump?
Do you need to remove the pully first to remove the power steeing pump.
Does the pully bolt turn the normal direction? |
Re: how do u remove steering pump?
Yes you need to remove the pulley first and you need a special tool to do it. You can get the special tool from Snap On or Matco dealer. Some auto parts stores may carry this special tool. You also need a special tool to put the pulley back on. Just had to remove ours from a 96 3.8.
kbreier
Are you trying to remove the pulley from the pump, or remove the pump from the engine? The pump comes off the engine with pulley intact. |
If we were to replace our power steering pump, to remove the pump from the bracket, the pulley MUST be removed.
I stand corrected. Never knew the '96 had that configuration. My Haynes recommends the bracket be removed at the same time...don't know if that helps.
remove 3.8 steering pump?
Just replaced head gaskets in our van this week, the end of the shaft has what looks like a allen head bolt but that is the end of the pump shaft, if you have an actual bolt that's new to me. I didn't believe they had bolts in them. To the best of my knowledge there is a bolt under the pulley that you will need to take out to get the bracket off. Maybe they added the bolt after our year, to keep the bolt threads from rotting out.
Re: Re: how do u remove steering pump?
Sorry, my bad about the hex bolt,I meant to say allen, but I just cant seem to get it to break loose. I'm afraid the bolt is going to snap.Oh well worse case I'll have to replace the pump.
Is the bolt head flush with the pulley??
The pulley is press-fit, not sure why the shaft is hex-cut like that, but on the '97 3.8l engine you just pull it off and press it back on. You can get a pulley puller/installer at Autozone for around $26. I just finished doing the heads on mine, so if you want some lessons learned, shoot me an email: dngrsone(a)sti.net |
I am no expert on going down that far.....I've been very lucky.....
From reading on this and several other forums.....the lower intake manifold gaskets are also a common failure....that can look like a head gasket...particularly in the coolant in cylinder or oil. Both the head gasket and lower intake manifold gasket can cause this. So....since you are removing the lower intake manifold to get to the head gasket...... I would want to put a new lower intake manifold gasket set in as well. Also...since you are removing the power steering pump....might be a good time to flush and replace the power steering fluid. It runs hot in the windstar....DO NOT use power steering fluid. You will need either "type F" transmission fluid or "Mercon" transmission fluid....depending on your year. I would recommend a synthetic that will take the extra heat. My '96 calls for a "type F" and I used Redline Power steering fluid (a fully synthetic)...which called out the Ford Specification number that is in my owner's manual. If your manual calls for a Mercon fluid....Mobil 1 would be an excellent choice. Using the wrong fluid....as in many cases.....can cause problems.... So it IS worth the extra time and effort to research and find the correct fluid that meets the Ford specifications. |
You mean to tell me I may have pulled the heads for naught! AAARRRRR!
I noticed that #1 piston is not going all the way to the top of the cyl when i turn it over like the rest of them. Its short by about 3/16",- What the *#@
