Old 10-30-2004, 07:31 PM
lwrdcav lwrdcav is offline
Exclamation How do i remove the strut bolt!
i have the struts out of the car and i have to remove the top bolt and it says theres a special socket made for it. How do i remove this bolt?
Old 10-30-2004, 07:45 PM
public's Avatar
public public is offline
Re: How do i remove the strut bolt!
I usually clamp the springs before removal and remove that bolt while it is still bolted to the car on the bottom. Good Luck.
Old 10-30-2004, 09:25 PM
godenm's Avatar
godenm godenm is offline
I usually brake the nut loose while still on car also. but if u hav strut off car and hav spring compresser already on it, you can take a wrench and turn nut and hold strut bolt with another wrench(10mm) wrench,...as long as nut is not frozen on too tight then it should come off o.k.
Old 10-31-2004, 01:14 AM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
make sure you have a spring compressor on when taking the nut off and on... i used an impact wrench..
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 10-31-2004, 01:53 PM
Langning Langning is offline
Go to Sears and picked up a 21mm (& 22mm as my replacement struts use a larger bolt) offset box wrenches. Use a smaller 1/4 ratchet socket to hold the center rod and turn the offset box wrench on the nut... Oh, put some penetrating oil on also help...
