Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 10-30-2004, 06:16 PM
sjthomas44 sjthomas44 is offline
2003 Sable keyless entry code
Does anyone know where to find the code for a 2003 Sable keyless entry
? If you have time a short message on the instructions would also be helpful.
Old 04-22-2005, 09:28 AM
esc2 esc2 is offline
If you are referring to the 5 digit code to open the door using the keypad on the driver's door, then here is what you need.
On the back of the fuse block, under the dash on the driver's side. There is a small white plastic tab that sticks out about 1/4 inch. On that tab is a printed 5 digit code which is the factory preset for that car. It is facing backwards, so be sure you read it that way. Just punch in that 5 digit code on the keypad and the door will open. If you want to set in your own code, just follow the instruction in the owners manual. If you don't have the owner's manual, just go to the Ford website and download one.
