Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 10-30-2004, 06:11 PM
picdaddy picdaddy is offline
2 4runners down 4 count or not, pls help
2 runners 87 with 22r and 90 w/ 3.0, the 87 just had a head gasket job done and at first it ran kinda rough and would not rev above 2800 rpms i took to dealership and they said scanner could not pic anything up so then thet tore the topend down and said the valves were a little tight they loosened and put bak together and said it now would not rev above 3500 rpms, so i picked it up and it ran ok 4 like 3 miles then would not rev above 200o rpms, it then died and would not run on its own again, heres the weird thing after it died i removed the key and the battery charge light and check engine light stayed on but kinda dim the vehicle has new headgasket, cap, rotor, wires, plugs
the 90 3.0 (auto)my shifter was loose and it would clunk into gear hard when it was cold now it wont move but when u put in d or r it tries but it feels like its not engaging all the way
any comments would greatly be appriciated
Old 10-31-2004, 12:28 AM
-HaVoC- -HaVoC- is offline
Re: 2 4runners down 4 count or not, pls help
You've gotta marry a chick whose dad owns a foreign autos repair facility
Old 10-31-2004, 09:43 AM
lol
Old 11-26-2004, 05:35 AM
forest_grump forest_grump is offline
On the 87 I would make sure timing is not a tooth off,timing set right,plugs clean and firing(see if it has spark,and do a compression check...and check for corroded and/or loose conections..are all the injectors (ticking)working???Check for corrosion in wires that plug into injectors,AFS,TPS,Ign... ect ect ect
Old 11-26-2004, 05:38 AM
On the 90 V6 model....Have you inspected tranny fluid to see if burnt and tranny fluid level while in park and engine running?(wipe and check several times as it is too tricky to see correct level on first try to trust)Goodluck ....
