Old 10-30-2004, 04:58 PM
B16Z6+S20's Avatar
B16Z6+S20 B16Z6+S20 is offline
Send a message via MSN to B16Z6+S20 Send a message via Yahoo to B16Z6+S20
Iacv
hi! can any1 tell me how to tune the IACV on my 94 civic ex, im having rough idle with the a/c on i cleaned the thing and cheked the hoses and still nothing, im not geting the check engine sign, but some times it works fine. and what is the litle pentagon screw on the side of it for? can the idle be adjusted there also ?
Old 10-31-2004, 08:15 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Iacv
vacuum leaks..
You only have a rough idle with the AC on?
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 10-31-2004, 11:05 AM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Re: Iacv
Mines the same way only mine is the EACV (but same thing). My car drops about .5k when I have my headlights on. It's really nerve racking
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 10-31-2004, 02:50 PM
B16Z6+S20's Avatar
Re: Re: Iacv
Originally Posted by superbluecivicsi
vacuum leaks..
yes, i cheked the hoses and dont have any leaks, and the idle get very low, like below 7000 but doesnt feel rough.
Old 11-01-2004, 05:45 PM
honda_luvr_2000 honda_luvr_2000 is offline
Re: Iacv
a low idle w/ the A/C on is actually a normal thing. It takes power for the engine to run the A/C that's y the RPMs drop. And I'm assuming you meant 700. My car idles at 600 and I don't have A/C or PS. As long as it isn't rough, then I really wouldn't worry
Old 11-14-2004, 03:27 AM
bingisSD's Avatar
bingisSD bingisSD is offline
Send a message via AIM to bingisSD
Re: Iacv
adjusting youre idle screw near the end of youre throttle cable is a sure way to bump youre idle up however much you wish. a low idle is not a real problem as long as is consistant and not erratic or fluttering. my idle flutters up and down which unless i have aftermarket cams is a significant problem. but having youre idle drop 200 rpm's is normal, its because y oure lil alternator only puts out oh say 70 amps and you have a small battery, when you turn off youre car youre lights dim too try hooking up a couple twelve inch competition subwoofers bumping it, while you have youre air conditioning on its the same way as youre rake pedal, pump it a few times and youre booster sucks up some power. power steering or windows as well.
but to 'tune' or rather adjust youre iacv you can just turn the little screw near the nifty contraption at the end of youre screw, it adjusts how open the little flap inside the intake manofold stays open.
www.cardomain.com/id/bingissd
http://www.automotiveforums.com/vbulletin/showthread.php?p=2660831#post2660831 <MEET IN DAYGO
