Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 10-30-2004, 04:21 PM
dcepar dcepar is offline
Send a message via Yahoo to dcepar
Corolla 98 check engine light code 441
The check engine light is on, and after checking with OBD, the mechanic said it's a code 441, and he thinks it is air flow sensor, or that it may possibly be just a dirty air filter. Does that sound correct? The problem that I have, though, is that the engine has had a tendency to die right after refueling when idling. Right after I refulel, the engine would die one or two times, but after one or two miles it would work perfectly fine again (not even coming close to trhe usual trembling / shaking stage)
I was wondering if the problem is related to the check engine light? Could both of those things be a matter of a fuel injection pump, or fuel filter? (I doubt, however, since the "dying engine" problem does not happen before refueling - when the tank is almost empty - but it it strictly happens right after refueling)
Thank you!
Old 02-07-2005, 05:41 PM
firedrewski03 firedrewski03 is offline
Have you tried fueling with the motor not running and see if the results are the same (if itll start right up or not)
