Old 10-30-2004, 04:18 PM
Prempt Prempt is offline
Removing the bed
I was trying to figure out today how to remove the bed on my truck. I am guessing it's the two pannels, the bottom of the bed and then the tailgate. I see some bolts that hold stuff together but it appears that the wheel wells in the bed are welded to the fender? Am I correct and if so how do I go about taking everything off the back of my truck. I am going to want to replace one of the fenders and the tailgate. It's a 1988 s-10 2d 2wd 2.5L
Old 10-30-2004, 06:29 PM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
Re: Removing the bed
There are 6 (or 8) bolts underneath the bed that hold it to the frame.Your bedsides are welded on and they just don't come off unless you cut the spot welds.Don't forget to disconnect the gas filler and the ground wire and unplug the taillights.The tailgate comes off easy.Disconnect the tailgate cables(yours aren't cables I know)Pick a hinge and unbolt it.Off it comes.Hope this helps ya.
Old 11-03-2004, 01:33 AM
OverBoardProject OverBoardProject is offline
Banned
With all that work and money going in your bed you might be better off adapting a newer rust free bed on your truck. I recently put a 98 Nissan box on a 85 Nissan pickup. It looks good, eliminated the rust problem. And with the newer box in I can lay plywood flat in the box.
Old 11-03-2004, 12:58 PM
Where can I find a list of beds from other trucks (Years and makes) that I can use?
Old 11-03-2004, 08:53 PM
Banned
Oh... Sorry I should have said. I just toured all the auto wrecks until I found a box that looked close, then removed it and paid the 100 bux canadian for the box.
I found the box at a self serve auto wreck, and lucked out The truck was torched and everyone thought that the box was fried since it had melted tar all over it. The melted tar just pealed off on a hot day.
My welder modified the mounts to make it fit right for 20 bus canadian... plus a 6 pack. And then we were done.
Good luck with it
Old 11-03-2004, 08:55 PM
What years/models can I put on my '88 s-10 frame though? I can't seem to find an '88 around here to get parts off of so I need to know what I can get that'll bolt up to my frame w/o to much modification of stuff.
Old 11-03-2004, 09:03 PM
Banned
The best bet is probably a late 90's chevy, or gm box...Even a toyota or nissan might be a close fit just check out the autowrecks in your area.
You can also place a box wanted in your city ad in this forum (some people might hate the idea) and you might get a response.
There are several clean boxes out there at an affordable price, you just have to look for them.
Old 11-20-2004, 06:53 PM
Upon inspection of my bed, I've found that only two out of the six screws are actually there. I am trying to hunt down a bed or I might fab my own floor and then get some new fenders if I can't find my own. The square bar that is welded to the bed is all rusted but the frame is okay, just has rust flaking off all over but everything is solid. My questions are.
1. Is the square bar tapped for a bolt or is there a nut I have to hold on the inside to lock the bolt in place
2. Is there a good place to get replacement bolts and screws or does a repair manual list the type of bolt? I am going to have to find new bolts for it b/c four are missing and the two are probably rusted to crap.
Thanks in advance.
Old 11-21-2004, 07:47 AM
1.yes.2.The bolts are metric thread,try to save one so you can match it up.
Stickerchick.com,best decals on the net
Click here
My $12.00 Sunfire
Old 11-21-2004, 08:41 PM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
Ok...I know this has no bearing whatsoever to the current topic...but in your sig movin2stereo..i noticed that you have your amp on the wall of your cab..I just put in 2 subs and an amp...and how did you attach or amp to the cab without screws going through the sheet metal out the back of the cab..
Thanks
Ryan
Old 11-21-2004, 10:05 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
use short self tap screws, he must of gone in through the plastic(guessing)
Old 11-22-2004, 08:04 PM
Re: Re: Removing the bed
Yes short screws and yes through the plastic.Funny because when I bought the truck there was screw holes all through the plastic and it looked like shit so I bought a new piece and wouldn't you know it.I did the same thing.
Click here
My $12.00 Sunfire
