Old 10-30-2004, 02:08 PM
nipsirc nipsirc is offline
Changing the Signal Light Bulbs - Front
I have a 1991 Plymouth Voyager LE with 3.3Liter engine.
I have done the back part but the front ones are a bit harder.
I would like to know if I can replace the bulbs without having to take off the front grill.
The manual says to unscrew the signal/turn light frame off but there are no scews to do that except the ones that fastens both front grill and the light frame.
Please advise if you have done this before..........
Old 11-01-2004, 10:28 AM
Re: Changing the Signal Light Bulbs - Front
any comments??
Old 11-04-2004, 07:16 PM
feedback?
Old 11-10-2004, 09:25 AM
Sport45 Sport45 is offline
Re: Re: Changing the Signal Light Bulbs - Front
Originally Posted by nipsirc
feedback?
Autozone has a decent online repair guide.
http://www.autozone.com/servlet/UiBr...3d8010cc53.jsp
Old 11-10-2004, 09:42 PM
hundahunta hundahunta is offline
isn't there one on the side of the marker light.. isn't the screws torx bit??
Old 11-11-2004, 11:05 PM
Re: Re: Re: Changing the Signal Light Bulbs - Front
Actually the one shown is a model 1985 till 1990... Mine is a 1991 and is totally different.....
Thank you anyhow....
Old 11-11-2004, 11:11 PM
Yes but only on the side bottom signal light. And yes it is all using Torx bit
Old 11-12-2004, 12:38 AM
you need to removed the 4 other torxs screws that are holding the front grill on.. and also when you open your hood and look on the top near the lamp assembly, there will be another torx a long one you need to remove that one also
