Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-30-2004, 02:32 AM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
From idle, shifter refuses to go into 1st gear. Must do 2nd, then 1st.
At first, it only happened 30% of the time, mostly when the car was cold. 2 months later, EVERY SINGLE shift into 1st from stop is met with fierce rsistance. The shifter REFUSES to go into 1st. Will slide into 1st if I go from 2nd to 1st, or if the car is gently rolling at around 1-5 mph.
97 GST. Good clutch, orig tranny, 115K miles.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 10-30-2004, 07:13 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: From idle, shifter refuses to go into 1st gear. Must do 2nd, then 1st.
How close is the cluth engagement point to the floor?
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-30-2004, 10:46 AM
Shpyder's Avatar
Moderate moderator
i would say almost near the floor.
clutch has 15K miles on it.
Old 10-30-2004, 11:16 AM
AF - Advisor
Thats most likely the problem, as I suspected. Bleed the clutch again. If proper bleeding doesnt raise the engagement point try using the pedal adjustment.
Kevin Jewer
