Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 10-30-2004, 12:33 AM
zutoo zutoo is offline
Unhappy Yukon Problems... :(
I have an '03 Denali and have had nothing but problems. I've had it almost a year now and it has been back to the dealer about 10 times. 3 times for the same problem... They replaced the factory amp, replaced nav unit, replaced YAW sensor twice, fixed a leak in the sunroof, and it still has problems! Every once in a while it wont start right away. I have to turn the key 4-5 times. And the sunroof started leaking again! The "Service Stability" light also came on a 4th time, after being fixed 3 times. But it turned off right away and the warning chime sounded different, so I think that time might have been a glitch. I love my Denali, but with all the problems I have had with it I dont know if I would ever buy a GM again. Anyone else have alot of problems, or did I just get stuck with a lemon?
Old 10-30-2004, 06:40 AM
the blur the blur is offline
hmmm, I too have an 03 Denali, and the exact same problems + about 20 other annoying problems. It's going back again this week.
replaced amp
replaced nav radio
still has radio problems since day 1
replaced steering box
now the steering wheel is off center.
front end clunks, that grease trick only lasted 1 month.
busted arm rest.
replaced both front seat belts
replaced turn signal switch.
steering wheel doesn't lock since.
exhaust poping
try pushing the brake pedal at a red light, it'll eventually go to the floor.
we had the service stability alert, but that seeems fixed...
The tranny would pop into neutral going down the hiway !!
I'm sure theres more... can't remember now...
Old 11-05-2004, 06:12 PM
DagDENALI DagDENALI is offline
Me tooo.
Here is the list of problems I have had with my 03 Denali, sounds famillair..
MILEAGE R/O# DATE PROBLEM
4,230 58666 4/01/2003 Right Heated Seat Inop, Power Mirror Inop, Power Locks Inop, Power Windows Inop, Interior lighting Inop, Keyless Entry Inop
11,100 62761 7/21/2003 Radio Trim Loose, Hood Paint Defective, Service Stability Light On
15,537 64265 8/28/2003 Service Stability Light On Rear Defroster Inop Doesn’t shift into Drive
15,742 65235 9/22/2003 Service Stability Light (2x)A/C Inop
15,742* 65433 9/26/2003 Service Stability Light On, ABS Light On, Traction Control Light On, Front Wipers Inop
20,090 66855 10/31/2003 Right Mirror Heat Inop
24,666 69921 01/23/2004 Recall 03011 Keyless Entry System, Headlamp out
32,832 74268 5/27/2004 Driver’s Seat Broken
34,262 75097 6/22/2004 Transmission Failure
38,225 77121 8/25/2004 Drive Shaft Noise (Part on Order)Heated Mirrors (Part on Order) Idle Erratic
38,257 77361 9/01/2004 Service Stability (Instrument cluster on order)
42,461 79745 11/05/2004 Drive Shaft Repaired, Idle Erratic (Unable to Duplicate) Heated Mirror, (part re-ordered) Driver’s headlight replaced.
Old 11-06-2004, 07:30 AM
I had more, just couldn't remember.
you refreshed my memory
my right side heated mirror was replaced, and now it's not heating again.
the power seate module was replaced 3 times.
there's more.
Now there is a nasty clunk from the rear.
Old 11-06-2004, 03:42 PM
just what you would expect from a cheap $51,000 vehicle, we should have spent more..
