Old 10-29-2004, 10:23 PM
GForce76 GForce76 is offline
Send a message via AIM to GForce76
Cooling Fan problem
I've tested the fuse. It's fine. I bought a new relay switch. Still didn't fix the problem. What would be the next suggested step in locating the problem of my camaro's cooling fan not coming on? Also I'm having problems with the vents not working w/ AC and Heat (floor and defrost vents work). I've seen other posts regarding this. But my question is, could these two problems be interconnected? Or are they seperate issues?
Old 10-30-2004, 02:38 PM
justlearning justlearning is offline
Send a message via AIM to justlearning
Re: Cooling Fan problem
well it could be your temp sensnor in the passenger side of the block it could be bad and need replaced though its very cheap. all though i relplaced the fuse, fuseable link wire, relay, and temp sensor and mine still wont come on unless i turn my air on so im stuck riddin around w/ my air on low all the time!! i guess ill have to search the past posts on how to put a manual switch in huh.
Old 10-30-2004, 07:30 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
try hard wiring the fan to a 12V source, if it dosnt turn on, then your fan motor has burned out. it needs to be replaced.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 10-31-2004, 09:41 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
does the fan turn on when you turn on the a/c?
*Better power-to-weight ratio than a C6 corvette*
Old 11-01-2004, 05:53 AM
It does not turn on with the AC on.
Old 11-01-2004, 07:49 PM
then put a new motor on very simple and do it yourself i did and when u bolt it back up make sure the fan spins freely otherwise it will burn another motor up but before u go buyin another moter check the fuseable link wire first and make sure it not burnt up its attached to a post on the side of the radiator and if the wire is original it should be a brownish orange or a rust color i belive
Old 11-01-2004, 07:56 PM
what about the test that 89 told you to do? did you try hard wiring it to the 12v source just to see if you could get it working at all. if it works on the 12v source than its prolly a temp sensor or maybe something else. if it doesnt work off of the 12v source than you need a new motor...
Old 11-06-2004, 02:05 PM
Finally put in a new fan motor, and low and behold it works... well sorta. It only comes on when the heat or air conditioner is turned on. I'm going to try the temp sensor and another relay now and change that out.
Old 11-06-2004, 02:44 PM
I read some of the other posts and came across one talking about radiator hoses and if they are hot or not. All of the hoses are hot except for the bottom one, when I started it, the bottom was cool to the touch, it wasn't as cool, but was far from being hot. Can that tell what part of the problem is? Also where is the temp sensor located? I've seen posts where some say its on the passenger side and some saying its on the driver side. The only thing I see that looks anything like it has been on the drivers side. Can anyone post a picture with it so I know if that is exactly what I should be looking at?
Old 11-06-2004, 03:49 PM
92rs25th's Avatar
92rs25th 92rs25th is offline
Send a message via MSN to 92rs25th
There is two , One right next to you rthermostat housing for Temp I believe and the other for block cooling control is on the Right side ( Passanger side ) down by the starter. Should be the only thing plugged into the side of your block with the exception of a dipstick - You can't miss it.
I love rice so much , I eat it daily. Yum yum Civic.
1992 RS Camaro 383.
2004 Mazda 6.
2003 Subaru Legacy GT Limited.
1984 Nissan 300 ZX
1993 Mazda MX-3 ( Newest addition to my collection. )
http://photobucket.com/albums/y187/ohjiro
Old 11-06-2004, 04:03 PM
So you are saying its on the driver side? With the one of the passenger side being block cooling control? As far as the hoses, i was wrong, they are all hot, first time i tested it i just let it run, this time i drove it around the block and every hose got hot.
Old 11-07-2004, 04:59 PM
Cooling fan problem fixed! Was the fan motor and temperature sensor. Thanks for the assistance.
