| Off-Topic Talk about anything other than cars. |
Do I need Turbo Coolant Lines?
Hey Im working on putting a turbo on my 1gNT and I've noticed on my friend turbo 1g I don't think he has coolant lines running to his 14b! it looks like they just have plugs on it! could I just run the oil lines, i only plan on running 5 maybe 6 pounds of boost. or if I do have to run the coolant lines where do they plug in?
Re: Do I need Turbo Coolant Lines?
With conventional bushing turbos like that you can get away with no coolant lines. My T67 isnt running any, and doesnt even have any ports for it ("dry center"). BB turbos dont get enough oil flow to cool the turbo though, so they have to use coolant. I would try the 14b without coolant lines and see if it works well enough. If it eats shit, they're cheap enough
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
my turbo doesnt have coolant lines and it makes your water temps cooler also.
1990 MIRAGE HB 4G SWAP FMIC ACT 2100 TIAL BOV TIAL WASTEGATE FIC 650"s SX AFR MAFT INNOVATIVE DUEL BB TURBO TURBONETICS MANIFOLD 255 PUMP WISECO 8:51 EAGLE RODS DELTA 272 CAMS SETRAB OIL COOLER AEROMOTIVE STARLITE HOSE AUTOMETER ROTA CIRCUT 8"S |
Water temp is regulated. It should always be the same temperature.
nice ya i really dont wanna run lines and that does make sense it would lower you water temp because then the rad doesnt have to work to keep the turbo cool aswell. I'm just going to throw some plug on it. Does anyone knoe if the bottom oil line bolts into the oil pan or does it bolt onto the block below the exhaust manifold?
The oil drain bolts from the bottom of the turbo into the oil pan, where the port/flange is for it. This thread also makes me feel reasured since my recent install of an evo 16g that I had to bend/kink the coolant lines to fit.
Aaron B. 95 TSi DSMlink'ed Evo3'ed 6 bolt 52.7 1/4 second try 11.0 1/16th 2nd in league. 22.3 1/8th Ties league record. 6.6 55 meters |
thanks, this is kind of off the origional topic but does anyone know if the stock 14b wastegate can support only running around 5psi of boost without modification? and if not what do you have to do to it?
The actuator is 9-10 psi, can't go below that. Might have to try getto rigging some other actuator on there, or see if mitsu offers a smaller one. Contact SBR (www.slowboyracing.com), I've gotten a few different actuators from them, and they do turbo NTs, hondas, etc, so they must have smaller actuators.
Thanks but i got another question for ya guys! do you think if I were to run 5psi on my N/T 4g63 do you think the air will heat up that much that'll i'll actually have to run an intercooler? like i want to play it safe! also will the n/t injectors and pump hold up for only 5 psi?
Oh, and btw Kevin, one of the mods on DSMtuners tried to run his T25 without coolant lines and grenaded the turbo in a couple of weeks.
1996 Eagle Talon |
Thats odd. I wonder if its becaseu the extremely small exhuast housing makes the turbo retain too much heat. That and it spins at like 160k rpm because its so small.
1996 Eagle Talon |
ya i called an import wrecker a couple weeks ago about the cooler and they said they would get back to be within an hour....2 weeks later nothing has been heard. I need to call them back. Can you really find em that cheap? if so thats sweet! but bout those injectors and pump i still dunno what i should do! i could just rip some off an old 5 speed turbo but as for the pump thier damned expensive for something so small! damn mitsubishi parts!!!
