Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-29-2004, 03:40 PM
story story is offline
Question is boring over/stroking really a practical mod?
what does boring and stroking really do for proformance is it even worth it?
Old 10-29-2004, 03:41 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: is boring over/stroking really a practical mod?
On what motor.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-29-2004, 03:52 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
a 4g63? , and if i was to rebuild my motor would that take miles off of it, or is it just a rebuild motor with 147,xxx miles still on it...because i really wanna slap a evo 3 16G on it , but i dont know if my motor can handle it..?
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 11-10-2004, 12:47 PM
i own a 90' eagle talon awd tsi as far as the motor i thought they ran the 4g63t however to my suprise when i popped the hood it said hyundia on the engine what the hell is up with that? any ways im considering a used engine swap with a low miles 4g63 engine so what would be the benifit of bore/stroking that engine would it be cost effective i mean there are other mods out there that could give you 15-20 extra hp for about 300 bucks (cat-back exausts)
Old 11-10-2004, 08:31 PM
AF - Advisor
Re: Re: is boring over/stroking really a practical mod?
After a full rebuild it will effectively have 0 miles. But either way you should be fine with a small turbo like a evo16g, unless your compression is currently bad. I wouldnt even think about rebuilding if the compression is still good. 1g you want 150-160 psi, 2g you want 170-180.
Kevin Jewer
