Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 10-29-2004, 02:57 PM
DMP43 DMP43 is offline
94 Bonneville Turn Signals - No Flash
Started last weekend. Intermittent at first now solid nonflashing.
- Bulbs light when I hit the lever but no flash.
- Changed signal flasher but no change.
- Hazards work fine.
- Fuse OKAY as well back-up lights on same circuit and they work fine.
- Checked rear lamps (okay)
- Haven't checked fronts as they are buried in the freshly rust-inhibitor sprayed front fender. I'll check tomorrow.
Any advise will be appreciated... DMP
Old 10-29-2004, 03:47 PM
hotinaz hotinaz is offline
Re: 94 Bonneville Turn Signals - No Flash
Are you sure you replaced the signal flasher and not the hazard flasher? Just a thought...
Old 10-29-2004, 06:21 PM
Wise Guy! But a good point! The flasher is adjacent to the steering column under a lower dash panel. I only saw the one under there but I'll check for the other...
Old 10-30-2004, 11:49 AM
Re: Re: 94 Bonneville Turn Signals - No Flash
O Wise One, formerly known as Wise Guy, the signal flasher was there buried deep in the bowels of the knuckle-dusting, skin-ripping dash! The factory item is a Wagner 224; however, a #552 (same as the hazard flasher) works fine.
Thanks for the tip...
