Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 10-29-2004, 12:53 PM
chris henry chris henry is offline
aurora troubles
Hey I got problems w/ my 1995 aurora...1st of all it won't start! I sprayed carb and choke cleaner in the air intake and it caused a loud pop and white smoke came from the intake manifold ...the smoke smelled like electrical wiring burning...so I took off the intake manifold and put it back together according to the manual....and now it won't start...fuel leaks from the injectors so I replaced the o-rings it solved the leaks but it still will not start...what do i do? can anybody help...?
Old 10-31-2004, 08:58 AM
97 silverbullet's Avatar
97 silverbullet 97 silverbullet is offline
Send a message via AIM to 97 silverbullet Send a message via Yahoo to 97 silverbullet
Re: aurora troubles
does it crank when you turn the key? Or does it just click when you turn the key?
[On his running for California Governor]
It's the most important decision I've had to make since 1978 when I decided to get a bikini wax.
-- Arnold Schwarzenegger
Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 11-15-2004, 01:30 PM
aurora troubles
the starter will turn but the car wont turn over
Old 11-15-2004, 02:31 PM
Sweet William's Avatar
Sweet William Sweet William is offline
Re: aurora troubles
The starter is spinning but the motor does not crank over?
Or is the motor cranking over just not starting?
Old 11-15-2004, 03:57 PM
zimaad zimaad is offline
If your not getting a hint of cranking over...sounds like lack of spark or lack of fuel. You have fuel pressure? When you changed the o-rings on teh injectors, did everything go back together correctly? Is the fuel pump working?
