Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 10-29-2004, 11:59 AM
Prelude707 Prelude707 is offline
Send a message via AIM to Prelude707
Unhappy Rev Limiter kicking in?
Ok I was stupid before in thinking my clutch was slipping at 6500 rpms. This is because I never kept pushing the gas to test it until now. I let off the gas the second I felt it stop accelarating.
Well after keeping my foot on the gas I have discovered that it isn't my clutch at all. It feels like a rev limiter that is kicking in at 6500 rpm. It's weird the needle will just keep bouncing against it. Isn't the idle rev limiter at 6500rpms? Why is it kicking in when I'm driving? Help me?
I took it to the shop that dynotuned the VAFC and after taking a look they said it has nothing to do with the tuning. They said on the dyno it had no problems and they tuned it to almost 8000 rpm.
2000 Honda Prelude
Mod list-
AEM CAI, AEM underdrive pullies, AEM FPR w/fuel rail, AEM brake pads, Apex'i N1 catback exhaust, Random Tech Hi-flow cat, Autometer fuel pressure & A/F ratio gauges, Apex'i VAFC(dyno tuned), ACT Xtreme pressure plate w/street disc and streetlite flywheel, Zex wet shot w/dual bottles and purge, Neuspeed front strut bar, VIS EVO CF hood, Honda Access door sills, NX bottle warmers, Lean Racing short shifter
Soon to come-
17" wheels, ES motor mount inserts
Old 10-29-2004, 04:54 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
Are you doing this while the engine is cold? The ECU will move the rev limiter down to the 6000 range when the engine's still cold.
Old 10-29-2004, 05:39 PM
Phunyguy Phunyguy is offline
Send a message via AIM to Phunyguy Send a message via MSN to Phunyguy Send a message via Yahoo to Phunyguy
Re: Rev Limiter kicking in?
i had the same problem.... i just took the car out tonight and pulled hard to 8500 rpms. *drool* - first time since the swap :-P - the ecu will move the revlimit down to 6800 regardless of vafc settings while it is cold.
Old 10-29-2004, 06:02 PM
No I always let the Prelude warm up to regular before shifting above 3500 rpms.
But that information has got me thinking. I currently am experiencing the dreaded boucing idle/cold start bypass malfunction. Sooooo maybe the ecu thinks it's cold even when it's not? Hmmm... I should try it out.
Should I just do the temporary fix, or should I just bring it to Honda dealership and have them install a new unit? Thanks guys.
2000 Honda Prelude
Mod list-
Soon to come-
Old 10-29-2004, 06:31 PM
install the obd1 ecu.
