Old 10-29-2004, 11:05 AM
Igovert500's Avatar
blue + red light magnet
10w30-->5w30
Gonna change my oil sometime next week when the weather gets warmer than 36 degrees. I'm considering switching to 5w30 due to the weather, as the manual suggests. Do you guys do this...notice any difference? I've never switched before, so I'm just wondering if you even notice a difference.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 10-29-2004, 11:22 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
Can't say that I ever noticed any difference (I kept the 94 running in the winters when I had her).
Resistance Is Futile (If < 1ohm)
Old 10-29-2004, 12:33 PM
Technical_Automan Technical_Automan is offline
Banned
Which manual is that? isn't the specified oil 20W-50?? and you should switch to 10W-30?? (I don't have the car manual)
Old 10-29-2004, 04:06 PM
Igovert500's Avatar
Re: 10w30-->5w30
I'm going by memory, but I'm 95% sure that's what it says in my 96 vr4 owners manual...
Yours may be different due to no turbos...just a thought
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 10-29-2004, 04:51 PM
osok_deadeye_21 osok_deadeye_21 is offline
I was just wondering that exact same thing. Ok i am putting 5w30 into my car right now and i know that is thicker oil right? ok so should i put thicker or thinner oil in my car for winter?
Old 10-29-2004, 07:48 PM
StealthModifier StealthModifier is offline
Re: 10w30-->5w30
Ive always ran 10w-30 in my car.. then i checked with the automotive store and they said it called for 5w-30. so i got that and i havent noticed a difference
Old 10-29-2004, 07:50 PM
crazy_quick crazy_quick is offline
Re: 10w30-->5w30
As long as you let your car warm up in the winter its all good.
Old 10-29-2004, 08:54 PM
Banned
Re: 10w30-->5w30
5W-30 is the thinnest automotive oil you can buy lol, little mixed up there. As far as the autostore saying that, better go back and make them look it up on the computer because you CAN run 5W-30 in any car, but that's not the manufacturer's recommendation. Too thin of oil means it won't lubricate the engine as well, leading to more wear (depending on the application). I remember the first time I went to buy oil for an oil change, I asked the guy which weight I should get, he said "5W-30 or 10W-50 will work fine", and I was like, "are you sure I heard something about it uses a different kind of oil". And sure enough when he looked it up it was 20W-50. But if you're going to have to deal with cold weather, i'd recommend 10W-30 and once warm weather hits again back to 20W-50.
Old 10-29-2004, 10:58 PM
Re: Re: 10w30-->5w30
just freaking great i just got my oil change today and put 5w 30 in it the mechanics there said 5w 30 is no different but i know it is which pisses me off cause these guys are supposed to know these things and help us out.
Old 10-29-2004, 11:23 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: 10w30-->5w30
I don't think theres much of a difference unless you run in extreem temparatures.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 10-30-2004, 01:24 AM
sLADe781 sLADe781 is offline
Re: 10w30-->5w30
Wait, is the 10w-30s just for the VR4s or any model? Because I have a '94 SL and have been putting 10w-30 in there because I thought that was the factory recommended oil. Which one is it for an SL?
Old 10-30-2004, 10:05 AM
Banned
20W-50, I thought it was that for both SL and VR4, but I only know the SL for sure. If you want to check, call up your local Mitsubishi dealer they'll have the right stuff. And Thorun is right about extreme temps, but in a high performance engine you're gonna want thicker oil.
Old 10-30-2004, 08:25 PM
Re: 10w30-->5w30
y do u put a thinner oil in during the winter?...so its not good to put 5w-30 in SL's?
Old 10-31-2004, 02:59 AM
Banned
Re: 10w30-->5w30
thinner warms up quicker in the winter, easier to move the engine parts, 20W-50 in cold weather would take a long time for the engine to warm, and make it difficult to start. I would say its not good to put 5W-30 in an SL if you do any hard driving. Grandma probably could, but theres a HUGE difference between 5W-30 and the recommended 20W-50. In winter 10W-30 will be fine, because of the temp. outside. I'm not saying you can't put any of them in, but it's the life your car you're talking about, you're gonna want what the makers suggest.
Old 10-31-2004, 06:24 AM
BB1970's Avatar
BB1970 BB1970 is offline
hi geoff,
0w-30, 0w-40 and 0w-50 is the thinnest oil available on the market at present.
the difference between 5w-30 and 10w-30 is minimal, you wouldnt know the difference in any way shape or form.
oil viscosity is recommended depending on your whereabouts in the world and the climate your car is in.
in the uk the spec on oil for a 3000gt is a 15w-40 mineral based oil which is used all year round.
changing the oil from 20w-50 to 10w-30 is a good idea for you guys in the winter as tech auto man suggests but personally i really do think that a 5w-30 oil should not be used in our cars. it is just too thin for our infamous tappets and i feel long term use with this oil could actually cause the tappets to fail completely.
ive been in the motor trade for nearly 20 years and its all very well this new oil coming out with higher specs than ever available for us but you must remember that our engines were produced and built from 1990-1991 and oil specification then was far lower than what they are now.
the tolerences in our engines are far wider than an engine is that has been produced in say 2003 hence oil being refined much more and thinner
the specs on oil for our generation of engine is acea a2 and is available in 10w-40 10w-30 20w-50 and 15w-40. any higher spec than that is good for our engines i.e fully sythetic oil etc but i personally would not go for a spec that is thinner than the ones above
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!!
9b turbos with manual boost valve mod set @14psi
turbo xs type h-rfl blow off valve
blitz dome filter
sachs clutch
completely de-catted
fuel pump voltage rewire mod
ebc redstuff front brake pads
greddy fully automatic turbo timer
now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
