Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-28-2004, 10:58 PM
rshottie1998 rshottie1998 is offline
Send a message via AIM to rshottie1998
Exclamation Trouble
OK...what would u do....if your cross member bolts were stripped out of the frame? i have one bolt in, but not both of them...how can i fix it?
Brandi
Old 10-29-2004, 12:05 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Trouble
Ouch! What type of hole is it? They are typically either threaded holes or there is a nut welded in. I dont work on NTs so I'm not sure what is used for the crossmember holes. Thats a tough one. Not sure I would trust a heli-coil in there. I might just weld it up and start over.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
