Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 10-28-2004, 09:39 PM
motocip motocip is offline
97 Rodeo rear wheel wobble, losing the battle
I have a rear wheel wobble that I cannot figure out. I replaced all 4 tires and installed new rear shocks. Still have wobble that fades in and out but never goes away. As I drive I adjust the drivers rear view mirror so I can see the rear wheel as I drive and can see it bouncing as if the shock was bad, noticably on a bumpy road, fades in and out on a smooth road. I had the tire shop recheck the tire balance and no change. If the tire is good, balanced, rim straight, and new shock, then what else could be causing this. I was told that a four wheel alignment may be the answer but that does not make sense to me. I have yet to examine the rear axle mounting bushings, but it was suggested. I just find it hard to believe that they could be the cause. Any suggestions would be greatly appreciated. I cannot afford to keep experimenting.
Old 10-28-2004, 11:00 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 97 Rodeo rear wheel wobble, losing the battle
Over inflated tire?
weak busted spring?
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 11-01-2004, 05:19 PM
StateTrooper StateTrooper is offline
Have tire balance checked somewhere else.
Check for seperated tread.
Old 11-01-2004, 10:19 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
bent axle shaft?
Old 11-02-2004, 09:53 AM
Jungleman Jungleman is offline
I think you should check your back bearings
