Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-28-2004, 07:42 PM
Machine1 Machine1 is offline
Stalls out
96 elcipse dohc non turbo
Just did my timing belt according to vfaq, everything went smooth...
(Even though nobody in town has the special tools and I had to make them) Also changed waterpump, pulleys, belts, wires, plugs, filters, the whole shabang!
The car runs and sounds great, no freaky noises or hesitations, but stalls after about 5 min warmup. It's driveable but I have to keep my foot on the gas at a stop sign. The idle is fine at about 1000rpm and I don't want to mess with it.
I've checked everything, wires and hoses, but haven't plugged or did anything to the EGR b/c it was fine before I did the timing belt.
I read somewhere that the coolant level might be too low, but the temp needle moves to where it used to in the steady state condition and the car doesn't overheat.
Has anyone ever heard of the engine stalling after warmup b/c the coolant level was too low?
Old 01-20-2005, 12:56 PM
mcdaddy5 mcdaddy5 is offline
mine too
yeah I had this problem too.
your intake side is the problem, make sure the hoses are tightly fitted and the you tighten the clamps this should do the trick. I'm finding the talon is pretty sensitive.
Old 01-21-2005, 06:44 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: Stalls out
Make sure you dont have any vacuum leaks or anything like that.
No your coolant level will not affect your car stalling unless you dont have any coolant in it. lol
Old 01-24-2005, 12:54 PM
Thumbs up
I feel your pain, mine did something simular
check the ground from the intake housing to the firewall.
My coolant light came on also, I filled to capacity. ran the engine the light contined to stay on and went off soon after.
hope it helps
Mcdaddy
