Old 10-28-2004, 06:34 PM
jdguy jdguy is offline
92 Ford f150 crusie control not working
Thanks to modtech for my gas problem. Cruise doesnt work. I have checked all fuses with an ohm meter. My horn honks so relay is ok. I know where the cruise control servo is but cant locate the cruise contol module. I have found voltage at the servo but want to check the module for voltage. What is the most common failure in the cruise control? I suspect by looking at the electronic shematic, that the control servo servo may be the fault. Help and thanks.
Old 11-03-2004, 12:12 PM
bby3 bby3 is offline
Please contact me with your phone number.
My name is Bruce York and I work for the National Highway Traffic Safety Administration (NHTSA). Please contact me at:
[email protected]
I am very interested in your CC failure.
Old 12-03-2004, 08:39 PM
wild bill wild bill is offline
check the safety cruise switch on the end of the master cylinder for the brakes. It can pass voltage but no amps.I,ve fixed a few
Old 12-17-2004, 11:32 PM
rickm8811 rickm8811 is offline
Re: 92 Ford f150 crusie control not working
i check the switch and open circuit no brakes closed with brakes applyed
is that how it should work???
RickM
Old 12-18-2004, 07:30 AM
the switch should be hot through the connector with no brakes applied the switch may not be carrying the current even though it may show voltage on a meter or light up a test light. I just replace them whenever i have a ford truck cruise problem.
Old 04-19-2005, 02:45 PM
gls1000's Avatar
gls1000 gls1000 is offline
Worked on throttle body recently?
Check to make sure all the cables are connected.
I'm the producer, of your nightmare, and the performance has just begun...
