Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 10-28-2004, 05:46 PM
Hit_N_Run-player Hit_N_Run-player is offline
Send a message via AIM to Hit_N_Run-player
Top or bottom mounted turbo?
Is there really any advantage or disadvantage of having a top mounted turbo manifold http://www.stockreco.com/01sap.jpg or a regular bottom turbo manifold http://www.stockreco.com/picture1006.jpg ???
Old 10-28-2004, 05:57 PM
Xtreme_098's Avatar
Xtreme_098 Xtreme_098 is offline
Send a message via MSN to Xtreme_098
Re: Top or bottom mounted turbo?
One on top ? No. One on bottom ? No. One on top and one on bottom ? No. Two on top and Two on bottom! Heh Oh Right.
Old 10-28-2004, 08:13 PM
Partizan's Avatar
Partizan Partizan is offline
Doesn't really matter, might help if you have a crowded engine bay or something but no performance beneift.
Old 10-28-2004, 08:14 PM
logik23's Avatar
logik23 logik23 is offline
Banned
Send a message via MSN to logik23
Bottom mount hides it so you can fool people...lol.....whatever...
Old 10-28-2004, 09:33 PM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
i think it has something to do with the heat... a top one alows for better cooling and alows for a lareg turbo to be instaled ... whatever, i have the stock one and it looks rusty...
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
Old 10-29-2004, 02:01 AM
i think i would get top mount, pop the hood and its like *BANG*, turbo's sittin there showin the beastness!!
1988 conquest TSI
-Lots of mods, finally finished WOOT!!
Horsepower sells cars,
Torque wins races!
Old 10-29-2004, 08:44 AM
mynismo mynismo is offline
yada yada yada
Send a message via AIM to mynismo
the main reason people do topmounts is for fitment. its usually too big to mount it in stock location.
438whp / 373tq - 11.9 @ 126
Old 10-29-2004, 05:16 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
The top mount gives easier acces to the turbo. Bottom mount allows for most of the downpipes made to be used. Top mount runs the risk of melting stuff in the engine bay.(i.e. brake fluid resovoir, wires, spark plug wires, just in general "shit").
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 10-30-2004, 12:04 AM
GT500916's Avatar
GT500916 GT500916 is offline
Banned
Send a message via AIM to GT500916
First question i want to know is, do you know what size turbo that is hes running there? the A/R on that or any info on that top mount turbo??
About the top or bottom mount, i heard that one can spool faster than the other, it is because the cooler the turbo gets the more lag you have.. as posted by AWDSR20 ... i remember reading that somewhere as well.
Turbos are ment to work off heat and pressure, hot air is prettu much energy for the turbo, if that air gets colder then it wont have as much energy. This is why its a good idea and some people do this , is wrap your turbo header with exhaust wrap to not let the head escape from the header and most of it goes in the turbo and spools it faster, so it slightly reduces lag.. I doubt its noticable, but if you compare chart im sure you will notice some different numbers if compared to top and bottom mounts.
I myself dont know which way ill go myself, depends what size ill get and how much room i have to work with. Plus You might want to hide those from some people, im sure cops know exactly what a turbo looks like so hide it, but if you dont care, show it off lol...
Get one mounted sideways!!! i havent seen that one yet lol...
Old 10-30-2004, 12:36 AM
honestlly i don't know if a top mount cools the turbo better.... (don't want to give the wrong info)
i think nissanfanatic explaind it best...
E.K.
Old 10-30-2004, 02:04 AM
logik23's Avatar
Banned
I'm pretty sure you want colder air, that's what an intercooler is for, I thught they wrapped the manifold and turbo so the heat didn't screw up other shit.
Old 10-30-2004, 05:18 AM
Re: Re: Top or bottom mounted turbo?
No, i was just posting that pic to show a reference of what i meant by top mounted so i wouldnt get a bunch of ppl confused on what i mean LOL...
1988 conquest TSI
Torque wins races!
Old 10-30-2004, 12:37 PM
240SX Guy
Heat is energy. We all know that. Too much or too little can be a bad thing. You want the most heat from the engine to be run through the turbine housing. Exhaust pressure, heat, and noise energy all transfer from the turbine housing to the compresor. Heat is the enemy on the compressor side of the turbo. An intercooler is used to dissipate heat created by the compressor. Most of the heat is created from just compressing the air but some is just transferred over by the turbine housing. This is why sizing is important. An improperly sized turbo can create much more heat than a properly sized turbo because of its efficiency range. You want at least above 60% efficiency. You can be picky and choose higher percentage, but 60% is about as low as you would want. Don't use wrap. Get the manifold ceramic coated. Wrap will destroy the manifold very quickly. Niether position is greater than the other for cooling. An oil cooler or water injection would be the best way of cooling the turbo faster. Niether spools faster(unless you assume that hot air is lighter and will rise into the turbo but that is irrelevant). Sideways is pretty much impossible on a 240.
-Cory
12.6@122mph
