Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 02-20-2002, 09:01 PM
Blue94G20T Blue94G20T is offline
What size tire's?
I currently have some 17x7 wheels with 215/40/17 tires on my 94 Infiniti G20T. Is this the recommended size? I want to get near the stock size diameter.
Ron
1994 Blue G20T
ShigSpeed Coilover, 17" Dronell TS05 wheels
Old 03-03-2002, 11:32 AM
UltraPete UltraPete is offline
http://www.toyo.com/tires/tire_specsheet.cfm?id=2
See if this link works. This is a tire data sheet on Toyo's website. Whether you're going to buy Toyos or not, at least this will give you heights for a variety of tires.
Measure your stock tire height and then look at the chart to see what 17" tire has the same height. Make sure to stay with about the same width or a little wider (about 20mm wider is probably the max)
