| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
boost controller
i have 95 tsi was wondering if anybody has made there own boost contoller. i made this one last night http://www.geocities.com/chmwatson/FAQs/mbc.html and from what i get u have to turn in to increase boost well it works but its turned all the way in and im running 13- 14 psi, just figured it would be higher then that. do i need a bigger spring, ball bearing, or longer bolt???
Re: boost controller
I'm willing to bet your spring is too soft. You can only set boost as high as the spring pressure in the MBC. Try a stiffer one.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
k, thanks
You did install it correctly and bypass the stock boost control solenoid, right? Check the tech article on DSMtuners for the proper install.
1996 Eagle Talon |
yea, i believe i did it correct one hose from the bov and the other from the wastegate. is that correct? thats what i got from the directions, oh yea i teed into the bov line.
