Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-28-2004, 03:56 PM
BrianEclipse BrianEclipse is offline
valve cover bolt seals
i went to auto zone and got a VC gasket and when i got back all that was in it was the gasket and 4 seals for the spark plug wells and nothing for the bolts which seems to be where the small leaking oil is coming from. i went back and they said they dont have them. thats weird cause i changed the VC gasket on my truck and it came with the seals for the VC bolts. please dont tell me i have to go to the dealer for the damn VC bolt seals. any suggestions? thanks oh yeah 99 gs NT
Old 11-03-2004, 12:19 AM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
i just changed my vaulve cover gasket 2 weeks ago and mine had bold seals with it
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 11-03-2004, 05:11 PM
well i called the dealer and he told me there were no such things its just washers. how many did you get? the VC gasket and the four other seals or did you get more than that? if you got more where did you go to get the set? thanks
Old 11-03-2004, 05:13 PM
Re: valve cover bolt seals
oh yeah plus mine is a gs NT what is yours?
Old 11-04-2004, 11:52 AM
xavier3jr's Avatar
yea i got the vc and 4 other seals i also have a gs nt i got 8 bolt seals and i got them from auto zone
Old 11-04-2004, 03:57 PM
ok wtf dude at auto zone must be retarded then. did the 8 bolt seals come with the gasket or did they come seprate? was it the felpro gasket?
thanks
Old 11-04-2004, 04:37 PM
xavier3jr's Avatar
yea they came with the gasket i dont remeber what kind it was tho
Old 11-04-2004, 09:10 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
u could probally use some O-rings that are the right size for the bolt...
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 11-08-2004, 10:38 AM
WankelTII WankelTII is offline
I bought one the other day, and there where 2 options, same brand. Prices: $18 and $8 the guy pulled them out to see what the difference was, and not only were they the exact same, but the MORE expensive one didnt come with the bolt seals or anything but the valve cover seal itself. So did you get the cheap one or the expensive one?
