Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 10-28-2004, 03:29 PM
Triffid Triffid is offline
Not another oil burning thread !
I'm sure you are all sick of hearing about oil burning but I just want to see about my case. I have a 1997 Saturn SL2 with about 88K on it. I currently have to put a quart of oil in it every 800 - 900 miles. Furthermore, my gas pedal is a bit sticky and I have heard that the problems could be related. I get about 31 mpg on the highway, which i also heard is a bit low for my car.
I took the car to a local mechanic who looked at it for an afternoon. He came back and said I would be best off replacing the entire engine and that he could do it for about $2000 parts and labor.
I guess my question is two fold ...1) Is that is really my best option and 2) will that fix all the problems I mentioned before?
Thanks in advance for your help
Old 10-28-2004, 04:54 PM
Chris101 Chris101 is offline
Are you sure that you are only burning oil? Is the valve cover gasket leaking?
Old 10-28-2004, 08:10 PM
Re: Not another oil burning thread !
Well... I don't know. Is there a way I can easily check. I am pretty new to this stuff so please explain. Thanks for your help
Old 10-28-2004, 11:33 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
i take it you are not much of a DIYer?
you many be in luck, are you anywhere near dupage county? i have some cleaning procedures i can do for you that may help. cost: $20, maybe $30 and about 12 hours. cheaper then a rebuild. if you are not in the dupage area, or you are more of a DIYer, read these two how-tos, they are basicly the same, but with a few minor tweaks. you may be able to convince your mechantic or your saturn dealership to do the first one, since it is a TSB(saturn approved procedure)
http://www.saturnfans.com/forums/sho...hreadid=38790&
http://www.saturnfans.com/forums/sho...hreadid=23676&
also be sure the PCV valve is from the saturn dealership, anything other then the OEM peice can also cause oil loss.
Old 10-29-2004, 07:31 AM
Well... I would have to disagree with about not being a DIYer considering I build my own speakers, cabinets, analog guitar pedals, computers and pretty much anything else I can do myself thats cost effective. I will agree that up to this point I havn't been an automotive DIYer, but that is what I am trying to change.
I have been frequenting saturnfans as well, so I did see those procedures you posted. I do know what a valve cover gasket is, but I can not visibly see any leaking coming out... so I didn't know if there was a more exact way to tell other than visually.
Old 10-29-2004, 09:03 PM
yes' i'm talking about wolfman's MMO soak, Lucas1's Internal engine cleaning, and cleaning the throttle body with carb cleaner, and maybe a steam clean too.
pull the sparkplug wires out of the valve cover and look in the holes, if the spark plugs are going for a swim in oil, then the valve cover gasket is bad.
Old 10-30-2004, 08:00 AM
Thanks man... I cleaned the throttle body with carb cleaner yesterday and poof... no more sticky gas pedal... awesome. I found the ects at auto zone yesterday so I am going to change that today too. I will do the MMO soak tonight... can't wait
thanks again
Old 10-30-2004, 02:34 PM
don't do that, in time you will have the same problem again, you should replace it with the OEM brass tipped sensor from a saturn dealership.
Old 10-31-2004, 02:08 PM
Re: Re: Not another oil burning thread !
oops, already did it. Think I should replace it again right away or wait? How will i know when it goes bad?
Thanks
Old 10-31-2004, 11:18 PM
you can leave it in there for now, expect to change it again sometime in the future, maybe 6 months maybe 5 years. a bad ECT will cause almost any problem you can think of. overheating, overcooling, power lose, poor fuel economy, hard starting, high idle, ect...
