Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 10-28-2004, 03:55 PM
roachd2 roachd2 is offline
Air Pump Noise
I just purchased a 2001 Aurora with a 3.5L engine and noticed the air pump has a loud whining noise on start-up for about 20-30 seconds.
Is that normal?
How loud is the air pump suppose to be?
Is it suppose to be lubricated?
Any info would be helpful - Thanks!
Old 10-29-2004, 08:39 PM
Autobanaurora's Avatar
Autobanaurora Autobanaurora is offline
Must be a California model, my 98 doesn't have one unless it is hidden, you sure it is a air pump?
Old 10-29-2004, 09:47 PM
Isnibs's Avatar
Isnibs Isnibs is offline
Do you mean the Electronic leveling Control compressor, a/c compressor, lumbar support air pump, or the air induction system pump?
1996 Aurora Black / grey
Old 10-30-2004, 09:09 AM
Re: Air Pump Noise
The noise is coming from the Air Injection Reactor (AIR) pump in the air intake area of the 3.5L engine.
Old 11-01-2004, 12:47 PM
kobalt kobalt is offline
Re: Air Pump Noise
The air pump is poorly located on the 2nd gen Aurora with almost unshielded exposure to dirt and moisture. Does the pump make the noise everytime you start the car or just once in a while? Are you sure it is the pump? If so, take off the splash shield under the front bumper - the pump is underneath on the driver's side. Undo the pump's hoses and thorougly spray compressed air in there (not from a can, the real thing). My pump's bearings were exposed, I don't see why you could not spray a bit of wd40 on there. Good luck.
Old 11-03-2004, 12:00 PM
Re: Re: Air Pump Noise
Thanks kobalt!
The pump makes noise everytime when it runs. However, it only runs whens the engine is cold.
I'll try what you suggested - thanks.
Old 11-03-2004, 04:18 PM
Re: Air Pump Noise
Excellent, let me know how it worked out.
Old 02-11-2005, 12:36 PM
Air Pump Noise Problem
Air pump had to be replaced. Good news was that it was covered under warranty because it is an emissions component.
