Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 10-28-2004, 02:35 PM
rash_vyas rash_vyas is offline
How to Replace O2 Sensor
Hi,
Can some one tell me how to replace 0xygen o2 sensor...in 1999 Honda Civic LX. Also where do I get this peice at the cheapest.
THanx & Regards,
Rashmikant Vyas
Old 10-28-2004, 02:51 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: How to Replace O2 Sensor
02 sensors dont come cheap. autozone is a good choice. $50 - $70 is a good price for a new one. OEM is best, but those definately do not come cheap.
To replace, use a 22mm wrench to take off the o2 sensor. snap off the connector harness. installation is reverse of removal.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 10-28-2004, 05:28 PM
Re: Re: How to Replace O2 Sensor
Do I need to take anyprecautions before doing this.
THanx & Regards,
Rash
Old 10-28-2004, 05:34 PM
AF - Advisor
just make sure the car has cooled down, or else, you will burn some skin.
Old 10-29-2004, 02:38 PM
Do I need to replace both o2 sensors...before and after Catalytic Converter...
Becoze cost of each is 67 - 80$ ...
Thanx & regards,
Rash
Old 10-29-2004, 03:13 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
just the one that is malfunctioning.
Empty Pockets Racing Member #1
Old 10-29-2004, 04:38 PM
AF - Advisor
Do you have a check engine light on? What does the code read?
Old 10-30-2004, 05:56 PM
Yes I do have check Engine Light on...As soon as I start my car it remains on Constantly...And I am getting code P0132 :- I believe this means Sensor Failure...Correct me if I am wrong.
Thanx
Rash
Old 10-30-2004, 08:14 PM
GScivic7's Avatar
P0132 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Circuit High Voltage
Old 10-31-2004, 07:58 PM
THanx a lot to everyone for the quick response...today I changed my O2 sensor and CHeck Engine light gone......
Once againg thanx to all, without all your support this was not possible.
Thanx
Rash
Old 11-02-2004, 09:27 PM
str3tch str3tch is offline
P0132...Where do I see this code in my car?
Old 11-02-2004, 09:31 PM
GScivic7's Avatar
you have to jump your ecu
Old 11-02-2004, 09:32 PM
what does jumping the ecu mean? did I get myself into something deep?
Old 11-02-2004, 09:33 PM
GScivic7's Avatar
http://www.superhonda.com/forum/show...ight=CEL+codes
