Go Back   Automotive Forums Car Chat > Nissan > Frontier | Navara
Old 10-28-2004, 01:56 PM
jezzeppi jezzeppi is offline
Blower Problem
Settings 1,2 and 3 for the climate control fan went dead at the same time today. 4 works fine. There are two fuses that are marked for "BLOWER" so I switched them and the problem did not resolve. Anyone???
Joe in NH
Old 10-29-2004, 04:24 PM
littlebrofl littlebrofl is offline
Re: Blower Problem
The Blower motor resistor is bad. Should be located under the hood on the passenger side on the firewall.
Old 10-30-2004, 11:57 AM
Thanks
Thanks for the tip, I will look at it and post.
Joe
Old 03-28-2005, 01:35 PM
zeamays1 zeamays1 is offline
Re: Thanks
The Blower Resistor is located behind the Glove box in the 2001 Frontier. This is a common problem which I experienced on my Frontier @ about 50,000 miles. You remove about four screws and pull out the glove box. The resistor is held in place by two screws. You will notice that the new part is re-designed so hopefully the problem won't happen again.
This repair took me about 15 minutes.
Old 04-29-2005, 02:42 AM
Vinhtvu2 Vinhtvu2 is offline
Re: Blower Problem
I have this same problem! I have no clue how to fix it! Can someone write a little in dept manual? maybe a pix of where the resistor is? Please? That would be Great!
