Old 10-28-2004, 09:23 AM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
turbo questions
about a month or so ago i posted a thread about my friend giving me a 16g turbo...well i didn't put it on because the exhaust side had cracks all over it....well i found an excellent exhaust side for it...i do have the compatibility kit for it so it can fit on my 97GST...
question 1 - how hard would it be to put the new exhaust side on?
question 2 - the turbo itself says on the side TD04HL...on google, i found that it was a 15g?
question 3 - the turbo itself has a mitsubishi symbol on it. would this thing be any better than my stock t25? would i even get a noticeable performance increase?
thanks for the help
Old 10-28-2004, 09:25 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: turbo questions
TDO4 should be 13g and smaller. Its no bigger than a t25. Look on www.vfaq.com and see if you can ID the wheel.
As far as changing the turbine housing, no problem. Just that one band clamp holding it on
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-28-2004, 10:38 AM
Re: turbo questions
all right so if i did stick this turboo on, i wouldn't notice any difference?
Old 10-28-2004, 11:11 AM
AF - Advisor
Re: turbo questions
Use the gasket to see if the turbine housing inlet (the part that mates to the exhaust manifold) is real small and offset to one side. If it is its a 13g or smaller. The water lines are different too, not sure about the oil lines. That turbo may not work with your install kit.
If the inlet seems the same it may have a Tdo5 hot side. If thats the case just toss that POS on there and see if there is a performance difference. Shouldnt hurt. If it doesnt add much power and you think its some small turbo, it would only take ~30 minutes to swap a 14b or 16g on there since the install kit is already there.
Kevin Jewer
Old 10-28-2004, 11:22 AM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: turbo questions
Since you're already planning on putting a new turbine housing (hot side) on it, I would recommend checking out the turbine housing that www.bullseye-power.com sells. I have read nothing but good things about them! Just by looking at the pictures of it you can tell it is a really nice piece. It also will put an end to any boost creep problems you may have - which is common with the 14b and 16g turbos. I would definitely keep that in mind, since it's such a good piece!
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
