Old 10-28-2004, 03:53 AM
Brandon774 Brandon774 is offline
Send a message via AIM to Brandon774 Send a message via MSN to Brandon774 Send a message via Yahoo to Brandon774
Question 5.7 TPI Vortec heads
I have a 89 Trans Am Gta with the 5.7 TPI motor and wanted to put vortec heads on it. Does any one know where I can get some good ones for cheap and are there any better ones then another. Also if I did that is there any thing else I should do if I where to put vortec heads on or can I just leave the rest of it stock? I aslo want to put better cams in it. What would be the best cam to go with vortech heads. Is there any things I should do when changing the cams to make every thing run smooth and right?
Old 10-28-2004, 04:47 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: 5.7 TPI Vortec heads
www.summitracing.com has a nice selection of heads and there tech line People can be a big help in finding the right set up for your project. Also welcome to the forum.
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 10-28-2004, 09:06 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
The vortec heads are a natural swap for the TPI motors, but the problem with bolting them on is that the vortec heads have a different intake bolt pattern than the older style heads, which makes the baseplate un-useable. Even if you were to modify it with a carbide bit to match up bolt hole wise the ports on the vortec heads are so much bigger that they actually rise up over the lip of the baseplate far enough to stick the end of a pen through. The solution to this is offered by Soggin Dickey Performance Parts. www.SDPC2000.com who have taken it upon themselves to custom design a baseplate to make this possible. designed spesificly for vortec heads and TPI it has larger runners and is worth more hp by its self. Right now i think the price is just under 400 dollars.
Vortec heads are plentiful at the junkyards across the country. Find any 1996-2000 CK platform truck (Silverado, Tahoe, Suburban and GMC equivilents) with the R code 350 engine. Pull the valve cover and check for the head casting number in the rocker valley, you want the heads with the 8? digit code ending in 062. The head castings ending in 908 have pressed in steel exhaust valve seats that limit flow and port modifications. The heads also have a max lift potential of around .480in lift. meaning a mild cam will have to be used, unless you have them machined for more lift. This is a pretty easy machine job that most shops are probly quite adept at by this point. it requires enlarging the spring seats, and cutting down the valve guides for dual springs.
The chambers on the vortecs are a bit larger than those of the stock 350, so a switch to steel shim gaskets would probly be a good idea. but even with slightly lower compression, the heads make more power. The swap to vortecs and the baseplate has been prooven to add 40-50hp to an otherwise stock L98 engine.
as far as cam swaps, it really depends on what the rest of your drivetrain is. you want the cam to match your engine, torque converter, trans, and rear gear ratios. To get a specific cam i would reccomend calling Comp Cams cam help hotline, its toll free, and they are the experts.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 10-28-2004, 09:08 PM
FormulaLT1's Avatar
Fight the powwa!!!
Who the hell said you where aloud to post in the Firebird Forum 89?
Old 10-28-2004, 09:24 PM
89IROC&RS's Avatar
i did, someone has to talk about something other than jello i had complaints about a lack of tech advice
Old 10-28-2004, 09:34 PM
FormulaLT1's Avatar
Fight the powwa!!!
Oh please, read the post over the past couple of weeks, I have answered questions from everything to 455 bolt patterns to LS1 CAI and then we all get to relax in the Jello tub. Your just upset the Camaro Forum doesn't operate so smoothly.
Old 10-28-2004, 09:52 PM
89IROC&RS's Avatar
haha, still love ya man, even if you are somewhat misguided and confused at times
Old 10-28-2004, 10:05 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Dude, listen to me, Vortec heads blow serious bunghole, get some edelbrocks.
Old 10-28-2004, 10:07 PM
FormulaLT1's Avatar
Fight the powwa!!!
And Geno is a expert on bung hole take his advice
Old 10-28-2004, 10:09 PM
89IROC&RS's Avatar
um, huh???? geno, im a bit confused, upon what do you base this conclution???? granted the edelbrock E-Tec heads flow more, but are majorly overpriced. IF i was gonna spend the dime on the E-Tec heads i would get the aluminum GMPP fastburn heads instead.
Old 10-28-2004, 10:13 PM
Genopsyde's Avatar
The President
i based it on the fact that I can't use them on my 305 without chopping them all up and hafta pay out the ass for some decent heads. So i'll just pout about my loss and stomp my feet and say they suck anyway.
Old 10-28-2004, 10:15 PM
Genopsyde's Avatar
The President
now that makes me think about your project, what combustion size did the 302 have?
Old 10-28-2004, 10:16 PM
FormulaLT1's Avatar
Fight the powwa!!!
I'm sorry 89 But I'm going to have to go with Lord of Poop on this one!
Old 10-28-2004, 10:21 PM
89IROC&RS's Avatar
lol, he wont have to cut anything up, the sell TBI/vortec intake manifolds for like 200 bucks *shrugs*
oh and the original 302's had small chambers, domed pistons, and 12.5:1 compression. ill have to do some lookin to find out exact numbers. with the vortecs im lookin at around 10.3:1 compression with the 61cc vortecs.
Old 10-28-2004, 10:25 PM
Genopsyde's Avatar
The President
oh no, I know all about the vortec tbi manifold, i meant milling them down so far to get the combustion chamber smaller and from what i've read, you can't mill them down far enuff to get the 58cc.
