Old 10-28-2004, 12:58 AM
hakelf hakelf is offline
Unhappy 97 voyager A/C Squeeeling
hi, I have a 97 Voyager V6 3.0L
The A/C was making a loud squeel every time I turned it on. After a couple of days it stopped and My A/C stopped working. I checked the belt and found it to be missing. So I had a new belt installed and the A/C worked again. Acouple of days later, the squeel came back, so I had the belt tightened, and that fixed it for a while.
Then the A/C stopped working. The belt is still there, tight, but no A/C. It doesn't even make that "click" sound when I turn it on. nothing.
Can anyone please help me with some advice on this. I cant afford to take it to the dealer again
Mahalo!
Jasmine
Old 10-28-2004, 01:00 AM
hundahunta hundahunta is offline
Re: 97 voyager A/C Squeeeling
was there any weird smell coming from the vents of the ac at any time...Possible low refrigerant...
Old 10-28-2004, 01:01 AM
ummm no I dont think so... would that cause the AC to quit completely? if the refrigerant was low?
I was thinking maybe a fuse or relay? what do you think?
Old 10-28-2004, 01:07 AM
Most of the times it is due to low refrigerant... These caravans are known to leak from either the evap coil or the right bottom side of the condensor...But is could also be a electrical problem...
Old 10-28-2004, 01:09 AM
so would low refrigerant cause the belt to squeel too?
thanks for you help btw
Old 10-28-2004, 01:12 AM
ohhh and... would I be able to check the refrigerant myself?
Old 10-28-2004, 01:15 AM
no. low refrigerant would not cause a belt squeal..a loose/worn belt or worn compressor clutch would cause this...
Old 11-03-2004, 05:51 AM
dno36 dno36 is offline
Re: Re: 97 voyager A/C Squeeeling
...or bearings in the compressor itself.
squeel = bigger problem usually unless it involves the auto-tensioner.
GL
DNO.
