Old 10-27-2004, 11:32 PM
da_b-man da_b-man is offline
Question Underdash Fuse Panel Cover Clips?
I recently got a 1990 Civic EX Sedan and when I went to check the fuses, I noticed that the cover was attached by a screw straight in to the steel plate under the steering column. It appears to be missing 2 clips of some sort to keep the cover up. Where can I pickup these things and what do they look like?
Old 10-28-2004, 07:12 AM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
Re: Underdash Fuse Panel Cover Clips?
yikes, but hey you have the same car i do yay
mine came with only the clip for the right side, i just went to the junkyard and got a new fuse cover (its blue instead of my grayish color though) with both clips. Now it doesn't fall on my lap when i hit a bump! So just check out your junkyard, or if it doesn't look too bad, screw in the other side. As long as it doesn't wiggle or fall off, you'll be fine.
You have any plans for your new car?
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 10-28-2004, 05:14 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Def. check out the yards. And be sure to find one that has tilt too cause they made ones with out the little angled part at the top of the panel so the steering rod can be lowered when tilt is active. My std didn't have that raised part but the crx dash I swapped in did.
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 10-29-2004, 12:08 AM
Re: Re: Underdash Fuse Panel Cover Clips?
Thanks for the info. Your car looks much better than mine!!! I have the ever popular Burgandy color that delightfully spreads into the entire interior!! It makes me feel like i'm in a 70's timewarp!! I actually just got the car from a buddy for $500 bucks cuz my truck burned up and my insurance hadn't paid me yet. I did invest in an a/c vent mount cup holder though. I just got a 2003 Toyota Tundra today so i'm passing on the love to another buddy that needs a car. Thanks again.
Old 10-29-2004, 09:18 AM
icE_x's Avatar
aww :P i have one of those cup holders too, comes in handy
you should keep your tundra as your daily driver and hook up the civic!! :P but if you do give it away to someone, let em kno bout the forumz
