Old 10-27-2004, 09:41 PM
72fbird's Avatar
72fbird 72fbird is offline
Send a message via AIM to 72fbird
Exclamation Engine doesnt start right
I have a 1972 pontiac firebird and it has trouble starting. I have to like pump the gas 3 times and then keep the peddle to the floor while turning the key. I literally have to keep the pedal to the floor until it starts and then push the gas a couple of times after it starts for it to idle right....Why?
Old 10-27-2004, 09:56 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Engine doesnt start right
Do you have alot of carbon build up around your butterfly's?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 10-27-2004, 10:09 PM
72fbird's Avatar
carbon build? i dont know but when it finally starts i smells like horrible amounts of gas and i flood it sometimes and i cant figure out why it wont start right
Old 10-27-2004, 10:12 PM
FormulaLT1's Avatar
Fight the powwa!!!
If you pull off your air filter do you have alot of black powder or moist sludge there?
Old 10-27-2004, 10:39 PM
72fbird's Avatar
no last time i checked i didnt and i looked for sludge a couple days ago cuz someone else was telling me to look for it but there isnt any
Old 10-27-2004, 10:40 PM
72fbird's Avatar
if i do how do i clean it?
Old 10-27-2004, 10:45 PM
FormulaLT1's Avatar
Fight the powwa!!!
A rag and some carb cleaner will do the trick
Old 10-27-2004, 10:56 PM
72fbird's Avatar
if there is no clogging what could the problem be?
i mean it literally will not start unless i have it full throttle for a good 5 - 7 seconds
Old 10-28-2004, 08:11 AM
savagewolf savagewolf is offline
it sounds like u need a carb rebuild, or a new 1. (get a holly) but before u do that, check the fuel dilevery system. make sure there is fuel pressure because the pumps go bad sometimes on the early 70's and 80's and also check for clogged fuel tubes and make sure the fuel filter isnt clogged (prob a good idea to replace it anyway.)
A great man once said "I reject reality and substitute my own" ...this is the key to a happy life.
Old 11-23-2004, 02:12 AM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
Sounds to me like choke problems
check all tuneup parts
