sr20 trany
I have an sr20det with a bad trany, will my old ka trany work? if not what is the difference?
it will fit but the gear ratios will be shorter... ( especially with pre 91)
Re: sr20 trany
The Ratios Are The Same.... 5th Gear Is Slightly Lower.
It Will Only Work Witht He Sr Bellhousing Swaped Onto The Ka Body. There Is A Slight Difference Between The Ka And Sr Trannies.... The Ka Has A Weak Point In The Tail Shaft Because There Is A Slight Taper / Reverse Bottle Neck Where It Goes Froma Thin Point To The Exposed Size Of The Tail Shaft. Under High Torque Conditions This Will Twist And Eventually Break.
IF I AM TYPING IN CAPS (LIKE NOW) I AM SORRY BECAUSE I AM AT WORK (DATA ENTRY) AND I HAVE NO CAPS LOCK BUTTON AND NO WAY TO CHANGE MY UPPER CASE LETTERING. SORRY! EMAIL CONTACT: [email protected] |
Re: sr20 trany
What clutch do I use or are they the same? Anything else I should know?
Re: Re: sr20 trany
What clutch do I use? Is there anything else I should know? |
