Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 10-27-2004, 05:58 PM
mcnu's Avatar
mcnu mcnu is offline
how do i take the front door panels off??
can someone tell me how to do this so i dont break the door panels?? thanks.
Old 10-27-2004, 06:21 PM
rodtice's Avatar
rodtice rodtice is offline
Re: how do i take the front door panels off??
1st pull out the screws at the bottom of the door. There is also a screw behind the door handle. I think thats all the screws. Then lift UP!!! the door, NOT OUT!!! you'll break the panel if you pull out. Once its free disconnect the wiring and your home free.
With everything when working on this car don't force anything and you won't break anything.
Old 10-27-2004, 06:33 PM
ejerry96 ejerry96 is offline
Another thing to remember when you put the door pannel back on make sure you have the vent essembled correctly or the damper will not open and close correctly. The "ASE" certified mechanic at the dealership where I had some work done as wasn't smart enough to check that. Also make sure that the wire harness is positioned correctly so the wires do not rub. That will cause a problem down the line. Don't get me wrong this is easy work. Just things I learned along the way.
Old 10-27-2004, 08:51 PM
mcnu's Avatar
thanks guys. i had the screw out behind the door handle, but i didnt even think to check for the other screws. i tried to pull the door off, and thats why i asked, because i didnt want to mess anything up. thanks again.
