Old 10-27-2004, 05:51 PM
tazmtiger tazmtiger is offline
Send a message via ICQ to tazmtiger Send a message via AIM to tazmtiger Send a message via MSN to tazmtiger Send a message via Yahoo to tazmtiger
Angry 97 chevy blazer engine shuts off no warning while driving!
Help! My truck shuts-off, really easy when you first start engine.. You start again and it dies again!
Sometimes Hazitates to start.
What can I do???
This problem started just a few days ago, after starting vehicle in the morning.. It just turned off, all lights turned off too, then engine lights came on.
I started engine right away, But. dies easy, unless you gass it.
At first, it was just once in a while, NOW... Vehicle turns off more often, even when engine fully warm.
Now: Car does not turn on as easy, and it dies without warning all!!
I can be driving it on the road, and it turns off in the middle of traffic,
leaving me in the middle of road when this happens. After this occurs.. The car usually won't start for about a minute or two, then starts, and then it dies just as fast. Becomming very difficult to re-start again. It seems to me that this happens more often as the truck's engine iddles down to normal speed, like: 'when I come to a stop at a traffic light".
ANYONE KNOWS WHAT THIS MAY BE??? NEED HELP!
THANKS!
Old 10-27-2004, 09:01 PM
diddy0071 diddy0071 is offline
Send a message via MSN to diddy0071
Re: 97 chevy blazer engine shuts off no warning while driving!
What can I do???
At first, it was just once in a while, not... Vehicle turns off more often, even when engine fully warm.
THANKS!
Well to me it sounds like 1 thing thats the problem, but there could be different problems to that 1 problem, let me explain.
The problem sounds like the engine is not getting enough gasoline.
to fix that problem, there are many things that can be causing the engine not to get enough gasoline. 1) when was the last time the fuel filter was changed? that might be the problem. 2) the O2 sensor might be malfunctioning, running the engine extremely rich, causing it to drown, or too poor causing it to not have enough fuel. 3) The fuel injectors might be too clogged to send gas through. I suggest starting with those possible factors, before going on to something else.
Old 10-27-2004, 09:33 PM
Re: 97 chavy blazer engine shuts off no warning!
Thanks for the hints... I am going to start with the fuel filter, I don't think it has been changed.. Then I will move the sensor and fuel injetor as you indicated. I will post back my findings!
Thank you!
Old 10-27-2004, 09:34 PM
just trying to help.
Old 10-27-2004, 10:01 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
#1 Problem with 1997
Ignition switch and that is your problem.
Do a search ignition switch in this forum and you will see the guides.
Old 10-27-2004, 10:37 PM
Re: Re: 97 chavy blazer engine shuts off no warning!
I am going to first change the fuel filter, then I will follow the suggestion down the ladder untill I resolve my problem. I really hope you guys are correct! Cause I need my vehicle. I Thank You guys for your postings to aid me with my truck troubles.. All of you people outhere are angels fallen right down to help!! Thank you very much!
Old 10-27-2004, 10:41 PM
BlazerLT's Avatar
AF -Advisor
Fuel filter will not cause an engine to shut down.
Trust me here, it is the black ignition switch box in the under part of the steering column.
But I guess you should change the filter if it has never been changed.
Old 10-27-2004, 11:14 PM
Re: Re: 97 chevy blazer engine shuts off no warning!
After doing a little more reading here and some research in other sites... I think you are right! I think the IGNITION SWITCH is the cause! I am going to replace the IGNITION SWITCH assembly which I found at http://www.buyautoparts.com/ and http://www.partsamerica.com/
For under $80. The same part can be puchased at the GM site for $129. I am posting a thread to the IGNITION SWITCH image, so. People with the same problem can see what it is all about. and also, to help others tell me if it is the right part?
http://catservices.wrencheadpro.com/...ACD/D1498C.gif
http://www.partsamerica.com/product_...N-UZ/US295.jpg
I thank you so much for all your help so far. I will keep you posted.
Thanks!
Old 10-27-2004, 11:27 PM
BlazerLT's Avatar
AF -Advisor
search for ignition switch in this section and you will find some people have already posted a guide for you.
Old 11-03-2004, 06:14 PM
Re: Re: 97 chEvy blazer engine shuts off no warning!
I want to Thank everyone that gave me advise to get my Chevy Blazer Sudden Shut-off problem!
You guys are great.. You were right in the money.
It was the ignition Switch...
Thank You!
Old 11-03-2004, 07:20 PM
BlazerLT's Avatar
AF -Advisor
Glad to help and thanks for getting back to us on it.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-03-2004, 08:27 PM
according to a very popular mechanic on TV & newspaper, a fuel filter can cause engines to shut down. either way, it was the ignition switch and that solved the problem, BUT i would still recommend the fuel filter be changed since they hadn't changed it for a while.
"I'm a jerk, not an asshole!!"
