Old 10-27-2004, 04:58 PM
kommy kommy is offline
hesitation
when i first start my 97 blazer theres a rough idle and hesitation when i put it in gear, especially when i havent driven it for a few days. also when it reaches the shift points there is a hesitation and feels like it isnt getting enough gass and i have to floor it for it to get enough gas to shift.
Old 10-27-2004, 05:16 PM
Mikado14 Mikado14 is offline
Re: hesitation
I assume that you have no codes. You may want to have the fuel pressure checked both Key On Engine Off and Key On Engine Running.
When was the last time you had a complete tune-up?
Old 10-27-2004, 06:40 PM
i do not have any codes. i changed the plugs and wires this past summer, i was told by my friend whos a GM mechanic that changing the fuel filter might part of the problem, it has 147,000 miles on it.
Old 10-27-2004, 10:23 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: hesitation
Yes, fuel filter should be changed every 40,000miles.
You are way overdue if it hasn't ever been changed and you are putting a lot of stress on your fuel pump having it push fuel through a clogged filter.
Old 10-27-2004, 10:33 PM
Re: hesitation
well i dont know when the fuel filter was changed last, i got it with 130,000 miles on it, and the person who had it before me was a salesman and took excellent care of everything else, so i dont know if they changed the filter, but thats what my next objective is, to change it
Old 10-27-2004, 10:43 PM
BlazerLT's Avatar
AF -Advisor
Re: hesitation
Sure, heed this advice with all car purchases.
Always assume the person before you NEVER took any care with the vehicel and do everything to bring the maintanence up to snuff.
Never assume anything was done just because he was a salesman.
Old 10-28-2004, 09:17 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Re: hesitation
yeh cuz when i got my blazer i knew the guy didnt take no care cuz it was beat to hell but she runs like a stallion now some minor problems but other than that a stallion
Old 10-28-2004, 09:34 PM
Re: hesitation
well i know for a fact that he kept it in good shape with maintanance and the interior, thats partially why i bought it, since it had high miles i made sure it was in good shape, this is the only problem ive had with it.
Old 10-28-2004, 09:54 PM
BlazerLT's Avatar
AF -Advisor
Re: hesitation
Oil changed regularly?
Transmission Fluid changed?
Fuel Filter?
Transfer Case and Differential Fluids changed?
Old 10-28-2004, 11:26 PM
Re: hesitation
yes, to oil change, i changed the tranny fluid, the transfer case and differential fluids were changed within last yr and i have a new fuel filter cuz he didnt know when it was changed last
Old 10-29-2004, 09:24 AM
Fireplug Fireplug is offline
Re: hesitation
The best way to tell if the fuel filter is bad .
Is to remove it and try to blow threw it and if there is a lot of back pressure its bad. You should be able to blow threw it with ease.
Watch out for the after taste
Old 10-29-2004, 02:15 PM
BlazerLT's Avatar
AF -Advisor
Re: hesitation
Or look for black colored fuel coming out the inlet of it when you unattach the fuel line.
