Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-27-2004, 04:18 PM
mmaurillo868 mmaurillo868 is offline
Tranny noise!!
i have this noise coming from my tranny i have no clue what it is when it idles it makes like a grinding noise than when i try to take off in first gear it like screeches untill i get into the rpms and like in the morning when i go to go to school when i try to shift to second it dont wanna go to easy but after that first morning shift it shifts perfect into second?
any ideas that could help me?
Old 10-28-2004, 06:07 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Tranny noise!!
Try to post what kind of car this is, turbo or NT. I'm going to assume its a 5 speed based on the post. But with the lack of punctuation its hard to tell even that Not trying to be a dick, but help us help you!
So there is a noise when sitting at idle. Does the noise change or go away when you push in the clutch? If it does I would suspect its the Throw Out Bearing. It could partially explain the tough shifting, but the fact that it gets better as it warms up also points to shyte tranny fluid. The turbo trannys do best with BG Synchro shift, or stock fluid. I have had good luck with a mix of Walmart fluid and stock. I have no idea what people use for NTs.
Get back to us on the TOB question, but change the fluid regardless.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-28-2004, 08:45 AM
it's a...
I have a 1998 eclipse rs with star performance stage 2 turbo kit. With a greddy sp2 cat back. It does go away when i push the clutch in. Is a throw out bearing expensive to replace?
Old 10-28-2004, 10:04 AM
AF - Advisor
Re: Tranny noise!!
Now we're talking! If the noise goes away with the clutch in, then its usually the TOB. Which is a good thing. Its only about 20-30 bucks. The bad news is the tranny has to come out to change it. If you can do it yourself, its no big deal, just a good days work. If you have to have a mecahnic do it, then its not so cheap. And if you need a clutch or planned to upgrade in the near future, now is the time to install it You will be changing the fluid in the process as well, which can help shift quality if the old fluid was no good.
Kevin Jewer
Old 10-28-2004, 08:27 PM
i need help with something else too.
before i installed the turbo kit i was runnin fine at idle. Now when im idling my car goes from 1000-800 is that normal for it to go up and down because beofre i got my fpr i was runnin a little lean and my o2 sensor got messed up so i need a new one but should i change my spark plugs too now after running lean.
Old 10-28-2004, 09:00 PM
Re: Tranny noise!!
Oh yeah i forgot to ask you something that i wanted to ask you when sometimes my car gets hott and it leaks coolant out the cap? Is this a bad thermostat or a bad cap im not sure what it is it only happens every one in a while when im really driving it hard.
Old 10-29-2004, 12:08 AM
AF - Advisor
Re: Tranny noise!!
IS the temp too high? Do you have a logger or aftermarket guage? If the temp is fine then its the cap. If the temp is too high, then it may be something. Fans not working, tstat, crappy radiator, etc.
I dont know shit about turboed NTs, but I'm assuming it still uses the map sensor? Or do those damn cars have a MAS. Shit, cant help you there. If its mas air metering though I Would suspect vac leaks first.
Kevin Jewer
Old 10-29-2004, 09:15 PM
Re: Tranny noise!!
it has a mas.. i got my catback exhaust on the other day but i heard this really annyoing noise from it its hittin on my suspension bar is taht fixable ?
Old 10-30-2004, 06:46 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: Tranny noise!!
since when does a 98 RS have a MAS? it has a MAP sensor, and my first suggestion would be to make yourself a boost leak tester and see if you have any leaks. check all the vacuum lines and the ISC to make sure thats all good. if that doesnt work... come back and post again!
Old 10-31-2004, 10:09 PM
Re: Tranny noise!!
I meant a map sensor but yeah i have no leaks.
