Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-27-2004, 01:56 PM
lionheartsails lionheartsails is offline
Headlights Dont Work - 1991
91 Mustang - Headlights do not work when turned on. Highbeams come on when lever pulled back but turn off when lever released.
Parking, Turn, Hazard, and Tail lights work. Fog lights do not work. All fuses in Panel are GOOD. Any ideas?
One mechanic says it may be related to an ignition switch recall.???
Is there a lowbeam/highbeam relay? If so where is it?
Old 11-02-2004, 02:08 PM
Mendari Mendari is offline
Re: Headlights Dont Work - 1991
It probably is a relay. I don't know where it is exactly, but they're usually under the hood of the car near the firewall. There will be a bunch of fuses and a bunch of relays packed into a black plastic box. You should be able to test the relay with a Multi-Tester.
Old 11-02-2004, 07:55 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Acutally it's one of two things. Either the headlight switch itself, or the multi-function switch (the directional switch).
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 11-03-2004, 11:12 AM
Re: Re: Headlights Dont Work - 1991
Originally Posted by HiFlow5 0
... or the multi-function switch (the directional switch).
Is this the stalk on the steering column?
Old 12-21-2004, 01:10 PM
importeater5_0 importeater5_0 is offline
Send a message via AIM to importeater5_0
lol i had same exact problem with my 91' what happened wit me is the high beam wire melted sumtin, so i took out my high beams wire and now it works good, but jsut no high beams
