Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 10-27-2004, 12:53 PM
Alpha One Alpha One is offline
Heat Problem; Replacing Blend Door Actuator Motor Assembly
I need to replace the Blend Door Actuator Motor Assembly on my 94 Sable. Can I replace it without removing the heater core and/or the Instrument Panel Assembly?
Thank you
Tony
Old 11-04-2004, 01:45 PM
KyooMac KyooMac is offline
Re: Heat Problem; Replacing Blend Door Actuator Motor Assembly
I need to do the same on my 98 mercury sable. I will be attempting to do fix it this weekend and was wondering the same. Does anyone have any suggestions on making this as painless as possible? I really do not feel like removing the dash.
Old 11-08-2004, 05:46 PM
Re: Re: Heat Problem; Replacing Blend Door Actuator Motor Assembly
I just finished replacing the Blend Door Actuator Motor Assembly on my 94 Sable. Yours is 98 and I don't know if it is the same, but mine can not be replaced without removing the dashboard, it would be impossible. However, I didn't have to remove the heat core, but it is a bit tricky to do. The space between the top of the heat core and the body of the car is very small. The Blend Door Actuator is in between the two. No way you can remove the screws ataching the Blend Door actuator base to the heater core, but you can pry off the Blend Door actuator from its base. Then you can press in the new Blend Door actuator. I had to be very carefull sliding it back and forth until I got it in place, but it wasn't that dificult. Onced you see the new one you will see how it ataches to the base.
Good luck
Tony
