Old 10-27-2004, 11:17 AM
wako528's Avatar
wako528 wako528 is offline
Question straight up
I read alot about swapin motors but I have a simple question I have 92 civic dx d15b7 4 dr i want to drop in a b16a(sir2) or b18c1
both jdm but which motor is better from a dead stop with there stock trans or should i swap the trans or what plz post your option
In life there is a winner and a loser and i Am ALWAYS THE WINNER!!
Old 10-27-2004, 12:14 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: straight up
The b18c1 because it has more torque. Stock tranny is good, you could change it out for the Type R tranny that comes with closer gearing and stock LSD. The LSD alone will help you get better traction from a stop.
Old 10-27-2004, 01:00 PM
wako528's Avatar
Re: straight up
what if your cruizin which is better
Old 10-27-2004, 01:06 PM
CivicSpoon's Avatar
There is no Spoon
Re: straight up
the stock GS-R one
Old 10-27-2004, 01:10 PM
wako528's Avatar
Re: straight up
anyone else
Old 10-27-2004, 01:53 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: straight up
GSR civicspoon is correct.
Old 10-27-2004, 02:01 PM
CivicSpoon's Avatar
There is no Spoon
Re: straight up
The reason I say get the GS-R tranny is because the early Integra Type R ('96-'97) have the same gear ratio as the B16a and Civic Type R. And the GS-R tranny has slightly higher gearing so you won't have to shift quite as much. The other option is the LS tranny that has the longest gears, but it will suck for acceleration when you're at the track; but be good for cruising and for gas mileage. So I figure go with the one in between (GS-R) for good acceleration and decent gearing for crusing. And it also had an option for LSD as well.
Old 10-27-2004, 02:35 PM
wako528's Avatar
Re: straight up
thx civicspoon what if I want to go trubo with would be the best
Old 10-27-2004, 03:02 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: straight up
b18b...has most boost friendly compression
Empty Pockets Racing Member #1
Old 10-27-2004, 03:04 PM
wako528's Avatar
Re: straight up
b18c1 or b16a(sir2) and why
Old 10-27-2004, 03:11 PM
GScivic7's Avatar
Re: straight up
b18C1, it has oil squirters and a block girdle. Makes it a little safer to boost. The best thing to do would use a B18C block with a B16A head. That's basically a poor man's Type R motor there.
Old 10-27-2004, 03:14 PM
wako528's Avatar
Re: straight up
should i replace the internals on the b18c1
Old 10-27-2004, 03:24 PM
Ace$nyper's Avatar
Banned
Re: Re: straight up
yes and yes to that.
even though you run less PSI on it it'll make more WHP then a LS boosting at the 2 or so more PSI they can take.
i'm doing poormans type R allmotor cause i'm teh sex.
how much $$$ and what are you goals depend on if you want to replace insides.
Old 10-27-2004, 03:40 PM
wako528's Avatar
Re: straight up
5 grand I want 300hp 250tq what about the stock axles u think the can take it
Old 10-27-2004, 03:45 PM
Ace$nyper's Avatar
Banned
Re: straight up
i'd rather not find outh the hard way with stock axles but i've seen stock guts GSRs push 300WHP before.
god forbid i can find you dnyo graphs to back it up sorry mate.
Tuning thicker headgasket good turbo set up and tuning good exhaust set up.
*i know tuning is listed 2 times thats cause its important enough to repete.*
