Old 10-27-2004, 10:17 AM
Magik Si's Avatar
Magik Si Magik Si is offline
02 Sensor???
Can anyone recommend a good online (reputable) dealer to get an o2 sensor for my car from? I've called around here and they range anywhere from $41.99 CDN (Universal where you have to splice the wires) to $251.75 at Honda...average is $103.53 CDN (before taxes). Some have told me just go with the universal...it's the plastic plug that goes in the wire harness that cost's so much...but...I'm not sure...help!
Jason
www.jasonlorette.50megs.com
90 Civic HB Si - D15B1 + MPFI
Old 10-27-2004, 10:42 AM
Juicy05 Juicy05 is offline
Id just go oem from honda, they seem to give the best results as far as reliability, i went through 2 bosch o2 in a month....
Old 10-27-2004, 10:58 AM
2ndb18's Avatar
2ndb18 2ndb18 is offline
Send a message via AIM to 2ndb18
Ya a oem honda one would be best. You shouldnt have to pay 241$ you can find cheaper than that.
88 civic dx
Old 10-27-2004, 10:59 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: 02 Sensor???
If you have deep pockets go for the one from Honda. If not, get the cheaper one. I'm using a Bosch one cuz I don't have deep pockets. I doubt it makes much difference for OBD0... And can somebody please verify if Bosch makes all the sensors?
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 10-27-2004, 11:31 AM
2ndb18's Avatar
They make most, but not all.
88 civic dx
Old 10-28-2004, 05:50 AM
Magik Si's Avatar
NGK makes some as well that I know of...
Why wouldn't it make a difference for OBD0? I know it's effecting my gas mileage..for sure.
Jason
Old 10-28-2004, 08:02 AM
Re: 02 Sensor???
Jason
Not sure if any other OBD... use single wire O2 sensors like ours do...
My gas mileage varies, but isn't terribly bad... just when I put my foot into it BTW, I used a burnt to hell O2 sensor for about a year and car ran ok most of the time.
2010 Honda CR-V EX
Old 10-28-2004, 12:16 PM
Magik Si's Avatar
The car seems to be "running" fine...it's just the gas mileage is brutal (300kms per tank)...my old STD used to get 500+ kms/tank...(Now have STD's D15B1 in my si...long story...with the si MPFI on it)...I was told when I swapped this engine in...9 months ago...that I should replace the sensor...just never did and eventually forgot about it.
Jason
Old 10-28-2004, 12:42 PM
2ndb18's Avatar
my 02 sensor isnt even wire up and my car runs fine and i think im getting the gas mileage i should be, 30-35mpg city and highways
88 civic dx
Old 10-28-2004, 12:47 PM
Shit must be nice i changed mine and im still gettin the code, my car runs WAY too rich im gettin 19-20 and i dont knwo why!?
Old 10-28-2004, 01:12 PM
Re: 02 Sensor???
Jason
You're losing a little in gas mileage cuz you now have 2 more injectors with your mpfi. Switch out your O2 sensor with a cheap one... just splice it in and reset your ECU.
2010 Honda CR-V EX
Old 10-29-2004, 07:38 AM
Magik Si's Avatar
Well...I figured that...how do I know for sure that my sensor is done? Is there any clear indication?
Jason
Old 10-29-2004, 08:03 AM
Re: 02 Sensor???
I knew mine was done for when I pulled it and was coated black...
2010 Honda CR-V EX
Old 10-29-2004, 08:56 AM
Would not having Catalytic converter cause a problem with the o2 sensor?
Old 10-29-2004, 09:12 AM
Re: 02 Sensor???
I don't think so, because the cat comes after the o2 sensor (unless you have a precat and postcat double o2 sensor set up). O2 sensors work best when hot. My air/fuel gauge always reads lean upon first start up until I get the o2 sensor nice and hot... usually when I put my foot into it, it'll pick up a correct reading. I thought I was in trouble with the red light continuously blinking on my gauge but it turned out it was just a bad ground on my accessory electronic fuse pad.
2010 Honda CR-V EX
