Go Back   Automotive Forums Car Chat > Ford > Falcon | Fairmont | FPV
Falcon | Fairmont | FPV Australian and American versions. Includes the XR6 and XR8 as well as FPV models like the Typhon.
Old 10-27-2004, 09:46 AM
heres_addy heres_addy is offline
Falcon Power?¿
Ive got an 84 XE falcon and just done a little work on it that includes:
#XF Engine (9.35:1 Compression)
#Full Rebuild
#Crow Cam (IN.30/70 EX.74/26)
#Crow Cam Springs And Retainers
#Stainless Steel Valves
#Redline Torker Intake
#350 Holley
#14" Aircleaner
#Redline Extractors
#2-1/2" Straight Threw Exhaust With 3 Inch Hotdog Tip
#T-10 Toploader
#Limited Slip Diff With 2.92 Gears
#15x7" XF Alloy Rims With 225 Tyres
The Power Range Is 1800-4800RPM And It Runs Premium Unleaded And Castrol Magnatec.
Air Is Forced Under The Bonnet By A Bonnet Scoop.
It Will Be Up And Running After I Sort Out The Toploader Linkages.
How Much Power Do You Think It Will Put Out?
Any Educated Guesses Will Be Greatly Apreciated!!!!
Old 10-28-2004, 05:27 AM
xyfalconsrock's Avatar
xyfalconsrock xyfalconsrock is offline
Send a message via MSN to xyfalconsrock
Re: Falcon Power?¿
hmmm,
I'd say 250Hp bit less.
great car,
bring down to victoria so i can see
Old 10-28-2004, 08:46 AM
Re: Falcon Power?¿
any ideas on torque?
it originaly had:
103kW at 3750rpm
316Nm at 2400rpm
Old 04-23-2005, 09:34 AM
oldschool muscle oldschool muscle is offline
How could that guy have told you 250hp you didn't say anything about what engine it was. I'm guessing it's the 4.1 if put out 103kw. Dunno maybe 170 to 200 kw. Sounds like you'd benefit from a higher pressure fuel fump.
Old 10-31-2005, 05:08 AM
Dirty Xf Dirty Xf is offline
Re: Falcon Power?¿
can anyone help im debating on a turbo'd eb engine or a dirty v8 to go in my 87 xf what would be cheaper and quicker
