Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-27-2004, 08:44 AM
suprcut suprcut is offline
'96 Cutlass Supreme Coupe
Has anyone had any success replacing just the headlamp bulb rather than the entire headlight? Is the bulb heat sealed onto the housing?
Old 11-07-2004, 11:46 PM
HDGP HDGP is offline
Re: '96 Cutlass Supreme Coupe
It is a weak foam/glue sealing the bulb and colar just twist it off I did yesterday replace with 9006 bulbs alot cheaper than the original units.
Old 11-11-2004, 10:10 PM
bbudziszek bbudziszek is offline
Send a message via AIM to bbudziszek Send a message via MSN to bbudziszek
the bulbs
Actually if you have a 96 Cutlass Supreme... there isnt really a way to do that without breking glass, but you can modify the mount to support a later model cutlass with a plastic housing. i havent done it yet, but if its works for you let me know
Old 11-12-2004, 09:50 AM
Re: the bulbs
I have a 96 Cutlass and I took the lights out of the glass housings and replaced with 9006 bulbs. You unscrew/pull the plastic retaining collar off pull the bulb out and put the 9006 bulb in. If you file/grind the tabs off the 9006 bulb you can reuse the plastic collar I used electric tape to retain and seal the bulb to glass housing I was in a hurry. But it can be done I did it in less then 10 mins.
