Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-27-2004, 01:31 AM
jb97gsx jb97gsx is offline
Send a message via AIM to jb97gsx Send a message via MSN to jb97gsx
need help asap
started my car one day and it ran funny...it idles at about 600 rpm's and just goes up and down up and down between 600-800...the code reads PO:100....Mass AIr Flow Sensor...had it replaced and it still says check engine and still runs bad....it also spudders sometimes when i hit the gas...or when i just rev it up it spudders then goes up and the BOV goes off...whenever i am going uphill it dies...not all the time but some of the time...i have a new Walbro 255 fuel pump so that cant be the problem...i also got out of my car one night and my exhuast we cherry red...but just at the muffler??...i have a bad exhuast leak right now but im sure thats not causing any of this...please help asap Thanks in advance.
if you could or want to help me...please add me it will work out better
aol - jb97gsx
msn - [email protected]
or just reply but adding me to one of them would be best thanks.
Old 10-27-2004, 07:22 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: need help asap
Sounds too rich. Are you sure the sensor was replaced? HAs anyone checked the wiring between the sensor and the ECU? You can use the ECU pinout and the diagrams for 2g MAS in a 1g from www.vfaq.com to figure it out I'm sure. If the mas is good for sure, and the wiring is fine, we're screwed.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-27-2004, 10:16 AM
Re: need help asap
it is running very rich, would that be every problem?? idling and all...my back end is BLACK!...i'll have to check the wiring...i bought a USED MAS but the guys at a perfomance shop here said it was still good..i'll have to check the wiring...if all thats fine...what else could it be...or would the engine just be F*ckd
Old 10-27-2004, 10:41 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: need help asap
do you have a aftermarket fuel pump regulator to control the overrun from your walbro 255? check the faq kevin wrote out all the reasons why you need one and not having one will make you run rich
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 10-28-2004, 05:50 AM
AF - Advisor
Re: need help asap
The 255 with no reg is certainly making things worse. But on its own its not enough to make the car undriveable. It will typically just max out the trims on the lean end.
You should never assume that just because you replaced a part, that part can NOT be the problem. It sure can Replace the sensor again, with a known good one. Check the wiring first though, a short in the harness somewhere could blow out good sensors, and you'll never get anywhere.
Turn the car off. Unplug the ECU harness connectors (4 of them, behind drivers side center console panel). Unplug the MAS. Using an Ohm meter, check each pin on the MAS connector to every other pin on the MAS connector. Repeat for all pins. This will at least rule out a short in that part of the harness. In fact if it passes this simple test I would be comfortable going ahead and trying another MAS.
Edit> This is where a logger would come in handy, and why I recomend everyone should have one. You would easily be able to check intake air temp, baro pressure signal, and airflow itself, to determine if the MAS is the cause of the problems.
Kevin Jewer
Old 10-28-2004, 10:21 AM
Re: need help asap
i dont think its the MAS anymore...i start my car and smoke comes from where the o2 sensor goes into the exhuast manifold..i ordered a new one so hopefully once i get my new one in the problem will be solved.
Old 10-28-2004, 10:25 AM
AF - Advisor
Re: need help asap
I've never seen a bad sensor allow smoke to pass. I dont think its possible. But replacing that sensor is a good idea, and I'm glad youre doing it. One more thing eliminated.
Kevin Jewer
