Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-26-2004, 11:15 PM
bclipse bclipse is offline
Still having problems
Ok well now for some reason when ever i put the car in Reverse it dies, but when i put it drive it goes but takes a long time to get up to 20 mph. Dont know how the hell this is happening.
Then i am still having the same problem with the gas, it sputters all the way to 3000, but when i get past that it starts to rev fine. I have tried everything to fix it. Could i have a bad WG actu.?
95 GS-T
'cause everyone thinks they're right, and nobody thinks that there just might
be more than one road to our final destination
Old 10-27-2004, 10:57 AM
jb97gsx jb97gsx is offline
Send a message via AIM to jb97gsx Send a message via MSN to jb97gsx
Re: Still having problems
i'm not sure wahts wrong, but mine does the same thing...sputters until 3grand then revs fine...is ur check engine light on?
Old 10-27-2004, 12:19 PM
No its not on. but is this when your just reving it, not moving right.Cause mine is not driveable right now
95 GS-T
Old 10-27-2004, 12:26 PM
mine does it while driving and just revving it...i can drive mine but it runs shitty as hell...i dunno whats wrong im going ot check the wiring from the ECU to the MAS today.
Old 10-27-2004, 12:35 PM
ok yea mine too, i have tried everything. Im thinking i have a fualty Wastegate, like the butterfly thing is having a hard time opening, but once its oepn my car revs fine. I need an Expert.This is the only time you will here me dick riding 95GSXracer where are you?
95 GS-T
Old 10-27-2004, 12:41 PM
Red face
me too man, we need a pro to help us on this one...i dont tihnk its the wastegate unless your turbo is not stock...my check engine light is on tho...and says the MAS is fucked up...but i changed it...so i dunno what else to do...SOMEONE PLEASE HELP US!!!
Old 10-27-2004, 03:16 PM
GSTRacerNVUS GSTRacerNVUS is offline
You know, as much as I like these little subforum thingys, I don't think everyone's using them as much. I still see questions on the main forum that could be put into a subforum.
97 Eclipse GST MT
Race Every Day Like It Will Be Your Last.
My one insignificant mod: Dump Tube - CUT
Old 10-27-2004, 05:29 PM
It could be your injectors. My car has me stumped and i dont know what else to do
95 GS-T
Old 10-27-2004, 06:39 PM
well i checked it out tonite...looked at it more..started it up...it revved fine,,, ran fine other than being very rich....but it was smoking...popped the hood...the smoke was comming from where the o2 sensor goes into the exhuast manifold...so im pretty sure thats just out...
Old 10-28-2004, 05:54 AM
kjewer1 kjewer1 is offline
AF - Advisor
I dont think the WG has anything t do with it. I'm having trouble determiing how many problems you have though. Is the not mving until 20mph thing because the tranny isnt working properly (I assume you have an auto)? Or is it simply because thats when you get to 3000 rpm? How "fine" is it over 3000, perfectly normal?
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-28-2004, 12:17 PM
Ok when im just in park it has trouble reving past 3k(because it sputters), but when it goes past 3k it revs perfect(normal). Then i have a hard time gettign to speed, its like i have mash on the gas let off mash on it agian that way it can get past 3k, but i haven't gone faster than 30mph.Could the trannie be stuck in 4th gear and thats why it is hard to get up to speed and dies whenever i put it into reverse, because the torqure converter is locked up
95 GS-T
Old 10-29-2004, 12:12 AM
AF - Advisor
HArd to say. But since there is a problem even in park, I would say its motor related. Trouble reving is usually a rich symptom. The first thing I would do is connet a logger and see if the trims are maxed out lean. Its possible that things are screwd up in closed loop, but when it switches to open loop it works fine. Really bad o2 sensor could cause that, along with anything else that affects trims. Thats a tough one, and I dont think I could figure it out unless I had the car here.
Kevin Jewer
Old 10-29-2004, 12:59 PM
The mechanic siad everything is good in the motor and it is probaly Electical: including the trannie. Make a road trip to Texas and help me out . Everything is new like the wiring harness from the computer to everything, the ECU, MAS, injectors. Damn this sucks. Ok well i pulled out the Trannie computer and turned it on, but when i put in reverse it still died, That means it is not electrical or what?
95 GS-T
Old 11-05-2004, 10:01 AM
Its my PCM. Are all years of eclipses interchangible or does it have to be from 95-99
95 GS-T
