Old 10-26-2004, 10:36 PM
z28 boy's Avatar
z28 boy z28 boy is offline
Send a message via AIM to z28 boy
Short shifting
So im at the track right. I pull up to the line and the tree starts dropping. WEll i hit the gas in D of course and i am off beating the guy next to me next thing u know the car shifts at 4500 rpms. I thought that maybe i had let off the gas so i keep going 2nd gear and again it shifts at 4500 rpms. it did that all the way down the track. It drives normal it just happens when i race it. ANy ideas what it could be that is causing the car to shift so early? its an A4 if u didn't already guess that.
R.I.P. Andy, A great guy and an even better friend.
2000 Z28 A4:
Patriot 226 cam, Comp 918's, Comp Ti retainers, HSW 100 shot, Vig 3600 stall, Richmond 3.73's, 2.5in TD's w/ H-pipe & 1-chamber flowmasters, 160* stat, TSP Lid, K&N filter, MSD wires.
Buried Needle Racing!!!
Old 10-26-2004, 10:51 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: Short shifting
are you in overdrive or in drive?
*Better power-to-weight ratio than a C6 corvette*
Old 10-26-2004, 11:16 PM
z28 boy's Avatar
Re: Short shifting
Drive
2000 Z28 A4:
Old 10-26-2004, 11:20 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
ummm traction controll????
just guessin.
BTW welcome back. where the hell have you been
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 10-26-2004, 11:32 PM
z28 boy's Avatar
Re: Short shifting
thanks, around. Oh and no its not the traction control cause i have it off.
2000 Z28 A4:
Old 10-27-2004, 04:15 PM
BrakeTorque's Avatar
BrakeTorque BrakeTorque is offline
If it HAPPENS* when your racing then its normal but if it just happen that once then id say its a RF or LF bad speed sensor. If you know how to use a diagnostics tool you can clear the codes when you race and should respond to whatever your gears are set at.
Old 10-27-2004, 05:32 PM
z28 boy's Avatar
Re: Short shifting
No it just started doing it. I have raced it plenty of times before and it would go all the way to redline. IT just recently wouldn't redline.
2000 Z28 A4:
Old 10-28-2004, 12:51 PM
z28 boy's Avatar
Re: Short shifting
Just waiting on Formula to come in and save the day.
2000 Z28 A4:
Old 10-30-2004, 12:09 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Short shifting
Is there a studder before it shift's or do it shift fast and firm at 4500 RPM ?and have you checked fluid level?. Also Sorry It took so long to see this.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 10-30-2004, 12:11 PM
FormulaLT1's Avatar
Fight the powwa!!!
Re: Short shifting
BTW, I don't think its a fluid level problem I think its computer glitch cause your Tach is off or Tranny shift point where set incorrectly but its goo to start with easy fixes first.
Old 11-02-2004, 06:00 PM
z28 boy's Avatar
Re: Short shifting
Its a hard shift and everything. It still chirps the tires but it just won't redline. Its weird. When i first started raciing i shifted it manually a couple times. SO i knew that to red line second gear i had to move the shifter right at 4500rpm so that the car would shift at 6200. Well the other day i tried it and moved the shifter at 4500 and it shifted at 5000rpm. The time of delay has shortened. Its redlining first now but it still short shifting 2nd.
2000 Z28 A4:
