Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 10-26-2004, 09:38 PM
93redcobra's Avatar
93redcobra 93redcobra is offline
brake light bulb ? part II
okay i changed the bulb and its still not working. The brake light bulb is actually a 2n1 bulb where the brake/turn signal are one bulb.The turn signal part works but the brake part does not work.any ideas?
In my garage
1993 red cobra
1999 lightning
2004 land rover
2004 lincoln navigator
Old 10-27-2004, 08:02 AM
CGGorman's Avatar
CGGorman CGGorman is offline
Re: brake light bulb ? part II
Just the one side? If so, I'd have say corroded terminals. Try cleaning the socket and wiggling the bulb. If both sides, I'd think the pedal switch is at fault.
Chris Gorman -LLSOC Forum Moderator-
2000 LS8 sport (lowered 2", LLSOC Intake, Magnaflow catback, tint, more..)
Old 10-27-2004, 09:02 AM
93redcobra's Avatar
yep just one side.what do clean the terminal with? thanks for the reply
In my garage
1993 red cobra
1999 lightning
2004 land rover
Old 10-27-2004, 11:44 AM
CGGorman's Avatar
You'll have to jury-rig something. Try a popsicle stick or other flat, slender object wrapped with emery cloth or other fine-grit abrasive paper. Blow it out good with compressed air or contact cleaner (or both).
Hope that helps. If not, you probably have a problem upstream. Could be a break in the wire or other connector.
Old 10-30-2004, 07:33 PM
93redcobra's Avatar
fixed it
In my garage
1993 red cobra
1999 lightning
2004 land rover
Old 11-01-2004, 12:55 PM
CGGorman's Avatar
Tease! What was the fix?
Old 11-02-2004, 08:46 PM
93redcobra's Avatar
used the wrong bulb
In my garage
1993 red cobra
1999 lightning
2004 land rover
Old 11-03-2004, 09:51 AM
CGGorman's Avatar
OOohh... That'd do it.
